Measuring lathe spindle/faceplate runout
Paul Waddle
>How do you use a dial indicator on the thread head stock shaft? I want to know if its the lathe spindle or the faceplate,or a little of both. Can't put the indicator on the threads directly,so what is the method? Thanks,pw
Re: Measuring lathe spindle/faceplate runout
eliot d
>The few times I've done it, I simply adjusted things so that the tip of the dial indicator was just touching the side of the spindle near its right end(furthest from the headstock) , and I turned the spindle by hand ( or under power at low speed) to observe the run out. I don't think there's much more to it. Perhaps some of the others know a better way. You would check the faceplate in more or less the same way, probably once perpendicular to its edge and once normal to its face near the edge. I checked the run out because I kept getting bouncing on certain turnings, but I since learned that the problem was in my technique, tool sharpness, and the kind of wood. It's probably not run out with you either. Let's hope not.
Eddie Pacheco: San Jose, Ca.
>Some if not all lathes have a non threaded shoulder that is near the bearing where you can place the dial indicator. While this non threaded area will also have two flats on it for a wrench, there is enough space to avoid this area if the ball on your dial indicator is not too large. Another area is on the inside of the Morse taper. Pick a spot near the end of the spindle and set your dial indicator stylus there. This has worked well for me.
Jim Swank
>You want a dial indicator with a flat tip, wide enough to span 2 threads so one is always in contact.
Don Evans
>I agree with Eddie, the place to do what you ask is INSIDE the end of the spindle (inside the morse taper) assuming it has one.
The other thing I would like to know is what exactly is the problem you are having?
I'm going to take a guess here and explain to you what many know and some don't:
Your spindle threads (if USA) are cut with a 60 deg angle or pitch.
This means that anything you screw on to them will wabble that much IF the end of the spindle bottoms out. All things you put on the spindle MUST have a 90 degree end that hits the flat area of the lathe where the spindle disappears into the head. Hope that is clear?
This area is called the registration area and it makes sure the item (chuck, faceplate, etc) is parallel to the ways.
If this isn't clear then I'll try again. Let us know. Maybe a picture?
Don
Re: Measuring lathe spindle/faceplate runout *LINK*
>Here is a good discussion of the topic of runout on a lathe.
http://www.aawforum.org/vbforum/showthread.php?t=4000
JohnKJordan in East TN
>I did it by cleaning the internal taper then mounting a MT drive center. There was enough machined surface extending outside the spindle for the dial test indicator.
For a chuck, you can grip a hardened steel cylinder (drill rod) to check centering.
For a face plate, assuming there is no "slop" in the bearings I can't see how any amount of runnout would matter. The chunk of wood is held in an arbitrary position with screws - neither axial or radial runout would prevent the piece from being turned perfectly round. The base is cut off anyway at the end.
>John I have 4" jaws on my chuck so I chucked a faceplate in the jaws and measured runout that way. I measured the inside of the morse taper and then did as you said, I put a drive center in and measured the blank area behind the teeth.
Paul Waddle
>Hey Don,thats good info,I understand the shoulder is what makes the face plate or chuck run true. I thought this might be the case,now I know. thks,pw
Paul Waddle
>The rub comes in when one swithes the chuck(face plate) and work to another shaft. As you suggest,as long as its on the lathe,doesn't make any difference,you turn it true.thks,pw. Well,we beat this horse to death-sorry for my lack of insight.
