Looking for ideas
Looking for ideas
Steven Antonucci
Looking for ideas
steve antonucci
>I have a shed that is 8'x12' and about 8' tall on my property. I would like to move it, and I'm trying to come up with a way to drag it across the yard without it falling to pieces. Anyone ever do something like this?
It is elevated on some concrete blocks, so I was thinking about building a giant dolly with some big wheels. If I can get it to that stage, I think I can roll it up the small hill and across the yard.
Anyone ever move a building without a crane?
Help appreciated from a creative crowd.
Steven
Re: Looking for ideas
Ron in Drums PA
>Wait for winter.
Build some giant shed sized runners (Think Sled)
Turn your yard into an ice skating rink.
PUSH!!!
Please take pictures
Curt Stivison
>Steve,
You may be able to get some round poles or pipes and put under the floor joists and roll the building. Once the building comes off the pole in the back, move it to the front and just keep pulling or pushing the building until you get it to where you want it.
I know you like to do things yourself for the satisfaction but a wrecker service could winch it up on a roll-back truck and move it across the yard in an hour or so.
CW
I like ron's ideas better
Curt Stivison
tek-Brunswick, Ohio
>Does it have a floor in it? If it doesn't, you will need to put some diagonal braces across the bottom to keep it from collapsing. Put down plank for your rollers to roll on and use pipe for rollers. The bigger diameter pipe you have the easier it rolls. 2" diameter should be enough. Jack up the shed high enough to get the plank and rollers underneath. You will need at least 3 pipe that are longer than the shed is wide. As the shed rolls the pipe will end up rolling out of the back. You pick them up and put them in the front and pull it until the next one comes out the back. Repeat and repeat until you get where you want. You only need 4 plank, but more are convenient. They are laid flat with one near each side of the building. Kind of like railroad tracks. As you roll off the end of one plank and onto the next you move the plank you rolled off of to the front of the plank you are now on. I wish I were there. It's easier for me to show you how it is done than to explain it. We moved a lot of stuff on construction jobs this way, when the object was too heavy to lift and we didn't have heavy equipment available.
tek-Brunswick, Ohio
>Ron's idea may be the easiest if you get freezing weather and snow where you live. The old timers used to wait until winter to move heavy stuff and do it that way.
Tom
eaglesc
>Keep an eye out near construction sites for schudle 40 S&D pipe.
I grabbed some 12" sections and moved an 8X10 foot out building uphill about 8 feet using that method by myself.
Jack up each corner a little at a time, put the pipe under and roll away advancing the pipe as you go.It helps to have a pipe mover.
(remember to have some chocks handy.)
sled
stacey s
>How about taking 2"x8" boards and attach two to make a 4x8 whatever length you need and put two on the bottom of the shed along the lenght. there are many many prefabricated sheds sold here in Southeast Georgia that come with these sleds on them. you can then use either a tractor if you have one or I would guess if you had big enough of a truck you could pull it across the yard with a truck, and I don't think that you would have to wait until winter, the biggest risk would be some damage to the grass from dragging the sled but I think that this would be the easiest and safest way to move the shed. just remember to attach your chain to the sleds and not the shed itself or you might just destroy the shed.
Stacey
Fog Tanner
>When we did that, the building was roughly twice that size. It was a fairly well building my father bought from a neighbor. We used some utility poles for rollers and a block and tackel anchored on a tree for most of the work. Then a lot of muscle to get it into the final spot before jacking it up and placing the blocks back under it. The utility poles were your normal diameter and worked OK - were not bent too bad. I was surprised that it moved that easily and only took three of us to get the job done, but that was over fortyfive years ago and they made people a lot different back then. WWII vets could do a lot back then, there wasn't anybody to tell them they couldn't.
Steven Antonucci
Thanks for the ideas...
steve antonucci
>I thought of the sled and rollers ideas, but I don't know how much manpower will be required to move the stupid thing. I've got some work to do to prep the new site, and one thing that I didn't think of was to wait until the ground freezes. I bet she'll roll better on hard ground, huh?
How much could a shed weigh anyhow? It's just a few 2x4's,some plywood and a few shingles ;-)
Steven
Peter Teubel
>Funny you should ask. I just moved my 8x8 shed to make room for a larger shed. Mine had a full platform made of 2x8s. I dug a hole on each side and used a car hydraulic jack to lift it high enough to slide 6x6 timber runners under it (I used a chainsaw to cut the ends to an upswept taper so they wouldn't drag thru the ground).
I fastened the rim joists to the runners with a couple 4x4 angle iron brackets, each secured with six 3/8" lag bolts. Attached a couple of tow hooks to the runners, connected a chain, and dragged it back with my truck. I had to spin it 90 degrees and push it to its final location. I did that with my truck also using the plow (pushing against the rim joists just above the runners). Worked fine.
Phil in NJ
>I saw a gardener around here with a bobcat that had a forklift assembly on the front. Have you thought about renting one of those or getting an hour of somebody's time for that?
Duane C.Leach
>Hi Steve. I used to move a lot of hog houses every spring. Some were in realy bad shap. Don't wait till winter the runers will be frozen down. Pry up the runners at both end, and put a rooler under it logs pipe work well. The biger the roller the easer to roll.
To pull the building you need a tractor or truck.A chain and a spreader bar. Fasten the chain to one runner on each side of front.fasten a sereader bar inbtween the two chains comminmg from the two runners.The other end of chain goes to the truck bumper or tractor toung.The spreader keeps the chains pulling straight
Happy turning
Duane
Dale Cook
>I agree with Curt. I moved a 12 by 28 foot building myself with round wooden poles and pipes, they were about 4 to 5 inch diameter. I jacked up one end with a handy-man jack and put a couple poles under it and the same on the other end,lowered the jacks and worked one end at a time with a long pipe or bar. I was surprised how easy it rolled. Good luck.
Don Evans
>GEEhs! You guy sure like to work hard!
I've done this twice and used the safe way that required no muscle on my bad back and didn't put friends in jeopardy.
All kidding aside, this may just depend on where you live, but around here there are a lot of small companies that build sheds for back yards. They have the equipment to do the job right and don't really charge that much to make a move as described. When you take the material cost, time, possible injury into account it is much cheaper to let them move it.
The guy I hired had a truck with a special bed on it with rollers and winch that they use to deliver the sheds they build. It's was just like a flat bed except the bottom of bed was all rollers, and it would tilt.
Anyway, $125 and it was moved first time about 25 feet, second time it was $200 but it moved several miles.
Worth checking into anyway, you may not be lucky enough to have someone near with the right truck.
Don
hire the job
JohnKJordan in East TN
>If you don't have the resources to do it yourself, there are people who do that for a living. When I bought a prefab 12x16 shed (with the runners), a guy brought it on a truck with a hydraulic sliding bed that can set down or pick up a shed gently. He said if I ever need it moved to another part of the property just give him a call. (And I didn't see this mentioned elsewhere, but if the ground slopes significantly anywhere along the path, this would be far easier than using rollers. Mine sits on a slope requiring 3' of blocking in the back corner.)
This one guy does nearly all of the shed moving for most of the dealers in this area and likely has a counterpart in your area. You might call a dealer and ask for a name.
BTW, if you need to beef up the support underneath: most of the small sheds I looked at are built on a 2x4 PT platform frame (covered with plywood to form the floor), the 2x4s laid on edge running across the narrow dimension; under that are three 4x4 PT runners running front to back with the ends beveled, the outer runners moved in a foot or so from the sides. On the site, the building is set down and placed on nine 8x16 cap blocks (three under each runner). First, the dirt under one corner is leveled with a spade and a block slid in under the runner. A second corner is jacked up and one edge is leveled using other cinder blocks as needed. Then the rest of the building is jacked up from the center of the opposite edge and leveled. Doubled wedges of white oak (4") are used for fine tuning. One Hi-Lift jack is all you need to place this type of shed and it can easily be done by one person.
Oh, and "Looking for ideas"? Here's one for no extra charge: empty out the shed before moving it! :)
>I think hiring the guy with the right truck might be the best answer, If you can get in there with the truck, etc.
I would move it myself. (If I couldn't use the truck) I paid to have 18 houses moved and watched how they did it. The "trick" is three point suspension. Two wheels in the back and a hitch in the front. Based on the geometry concept that three points establish a plane. So, If you put two timbers under the building with wheels on the back and hook a hitch to the front, the two timbers will remain in a plane and your building will not be torqued and twisted.
I moved a building recently by putting two timbers (2 2x8 each) under it like a V. The wheels went on the wide end and I just dragged it from the front or point of the V. For wheels I bought two hand carts from Harbor Freight (600 lb capacity each) and used the axles and wheels. My original intention was to just strap the hand carts to the timbers, but I couldn't get the tires aligned that way. I borrowed another hand truck and just hooked it under the point of the V and rolled the shed around fairly easily. I still have the two HF hand trucks that I put the axles back into and I used the 2x8's as a foundation for the shed in it's new location.
Actually, I hitched my cat to the front end of this and got him to pull the shed up the hill. At first he could not move it and I had to use the whip.
That's A joke. Don't start on me about cats. I like cats.
They are tasty.
Steven Antonucci
A picture is worth 1000 words...
steve antonucci
>I figure this might help the situation.
Here's a picture that documents the major part of the dilemma: an uphill lie. I have the shed on cinder blocks to get it up off of the ground (and they were just lying scattered throughout the woods when we bought the house...)
The ramp crosses over a mushy spot that should be a french drain, but isn't . The overall area is pretty firm, but that hump that I have to come up onto is my septic field, so i'd like to minimise the dragging across the yard. There's no way to get a truck back there (that's why I stick built the kit in the first place...), but I might be able to carefully navigate my truck back there for towing.
If I can't, how many folks do you estimate it will take to drag it up on rollers (empty, of course :-)?
Steven
Steven Antonucci
Re: A picture is worth 1000 words...
steve antonucci
Carol - now in NC Nebraska
>3 plus a come-along. The come along provides the muscle. Two people provide steering, watching both sides, and moving peeler pole rollers. The third operates the come-along.
I have to do the same thing to a 10 x 16 next summer. And I have tree stumps (albeit low ones) to negotiate. And the final site is on columns, so it has to be jacked up 4-5 feet as well!
Fun times.
Ron in Drums PA
>Are there any farms by you?
Hire a farmer with a tractor to help you out
David Breth
>Steve -
A few years ago, I purchased a gigantic wooden swingset/fort thing from a guy in the neighborhood. I was ready to tear it down, mark parts, then reassemble. No, no, he says, he works for a car dealership, he can bring one of those flatbed truck jobbies for towing cars, and he can tilt the bed down. It was easy, it worked well. The downside what that it was a bit wet outside, and he buried his rear wheels up the axle. A lot of swearing and effort was required to get that #$@$%**&%&#$@ truck out of my back yard.
So - if the back ground is pretty firm, and you have access to that kind of equipment, it might work pretty well for you.
David B.
Re: A picture is worth 1000 words... *LINK*
Speaking of comealongs, after going through many cheap pullers, I finally found one built to last. Used it for many pulls and felling large trees.
The link shows one. Mine didn't come from there, but it looks the same. It has an extra pulley for doubling the pulling power.
http://www.izook.com/reviews/mppuller/mppuller.htm
Rent a bobcat
KurtK in Indy
>If it's in your budget, rent a bobcat for a morning with fork attachment. You may be able to get a skid loader also. They have fork extenders and with a little creativity (and maybe a couple hundred $$)you should be able to get under that barn and move that guy fairly simply.
