Hunter Tool For Kelton
Dave Winters
>Anybody making a mod for using the Hunter tool in a Kelton rig? 5/8" dia.
Thanks, as always-
Snow on the mountain this morning!
Dave in Steamboat
Dave Winters
Thanks, as always-
Dave in Steamboat
Re: Hunter Tool For Kelton
George Van
>Dave, I use the Trent Bosch 3/4" tools in my Kelton rig with the Hunter tips. Are you planning to mount them on your 5/8" Kelton bars replacing the laminated HSS laminated tip?
Dave Winters
>Yeah, George, my Kelton uses 5/8... doesn't it? How do you like the Hunter tips? Is the Bosch turned down to 5/8? Now I'm confused. (which doesn't take much)
Thanks, Dave
George Van
>Dave, I just went down to the shop and the Bosch are ��, had to double check. One end of the Kelton takes these, I believe without the reducer bushing. I do like the Hunter tips, they keep very sharp. They are not a finishing tool as the radius is small. I am going to try my #6 Hunter tool in the Kelton, that too has a �� shaft but has a larger cutter, thus a larger radius. I also Have a cutter to try in my Rolly Munro tool. I finally got a nut for the screw and just need the time to try it out.
>George I respectfully disagree that the Hunter is not a finishing tool. I have been able to get an exceptional finish even with the #1 tool. It's all in how you present it to the work and fast you pull it through the cut. I tilt the tools at 50 to 75 degrees (aprox) depending on the wood and direction I'm cutting. This is my finishing cut. I can usually start sanding with 220 if I've done my job correctly.
George Van
>John, maybe my finishing cuts are due to lack of experience but I still have a difficult time in a hollow form with ripples and need a tear drop shape to smooth the tool marks. I will be more careful and follow your technique on the next one and see if I can improve. I have no problem on an open end grain form and have had results similar to yours.
>George. I misunderstood. I was talking about finishing cuts in general for things like vases, boxes and other open vessels. For hollowing through a neck I have the same problem. It isn't the Hunter tools fault, it's mine. Like you if I need a really clean finish inside a hollow vessel I go with a larger softly curved scraper.
My friend John Roberts is one of the best people I know at finishing the inside of a vessel.He said the trick is to imagine your touching the back of your hand with your fingernail and you can barely feel it.
Using a 3/16 HSS cutter or the small Hunter tool I still get little ridges. I don't think I am doing that because I pull the tool back as smooth as I can. However when I cut through the side accidentally and look at the inside it's all full of waves. Not bad waves, they are more of a visual and tactile thing. You can't even really feel them when measuring wall thickness. Oh well, more practice is the key word here so I better shut up and go turn.
