Nova Soft Jaws
Nova Soft Jaws
Nova Soft Jaws
Philip Duffy
>Am I the first to use these beauties? Mounted them this morning and put them to use on the midi-lathe and found them to be great for small stock items, like bottle washers, ornaments, etc. Did not even bother to cut a distinctive pattern, just used them out of the package. They ran smooth and true, and they don't need individualized mounting, they are all interchangeable. Too bad they are made in China, vice New Zealand!
No product affiliation, etc. Philip
Re: Nova Soft Jaws
Mike Stafford
Re: Nova Soft Jaws
Mike Stafford
>I also have a pair of them and want some more to modify to different shapes for reverse chucking some of some of my boxes. I have not found a source for them except through their web site.
Re: Nova Soft Jaws
Re: Nova Soft Jaws
>I did not know these were out. They look interesting, but why wouldn't you just make them? Is there something to them other than pieces of nylon with holes in them? Couldn't you just take four pieces of wood and drill holes? Or am I the only one who actually enjoys making things like this?
Re: Nova Soft Jaws
Re: Nova Soft Jaws *LINK*
Larry Bisbee
>Nova Soft Jaws are currently available at Woodcraft (Part Number 148043) for $14.99 and can be found on there web site.
http://www.woodcraft.com/family.aspx?familyid=20292
Re: Nova Soft Jaws
Mike Stafford
Thanks Larry,
Mike Stafford
>I hadn't noticed them in the catalog. I must need glasses.....
Re: Nova Soft Jaws
Steven Antonucci
I thought the same thing
steve antonucci
>and then I realized that the issue is in the accuracy require of both the holes and registration grooves on the bottom. I can't drill a straight hole worth a dang...let alone an exact spacing.
Still, I am going to try it...so end grain or side grain?
Steven
Re: Nova Soft Jaws
Re: Flat side grain, Steve. :-)
Allen Neighbors
Re: Nova Soft Jaws
ebd
Re: I thought the same thing
ebd
>I've built essentially the same from 8/4 framing lumber cutoffs, clear - of course. I cut a circle on the bandsaw and attach it centered as well as I can on a chuck with mini cole jaws attached and closed tight. True it up. Then mark each edge where the cole jaws meet and number what will become the segments the same as each jaw they are mounted to. Unscrew the trued circle, use a straight edge to mark from each edge mark across the center to the one opposite it, cut on a bandsaw. DONE. I make them different sizes and true them to finished diameter for the bowls/boxes I miscalculate on and don't have jaws that will fit for reversing. I also use them to make special jaws to hold delicate edges. You can turn them to a perfect and very tight but gental fit and they are essentially free. I re-turn them to any size I happen to need and discard them when they become too small or specialized. Then I take a few minutes and make a replacement set.
Re: Nova Soft Jaws
>I have a set of Cole jaws and I made a set of hooks for them that extend the capacity to the 16" capacity of my lathe.
Before I got the Cole Jaws I made a set out of Baltic birch plywood. I mounted four squares on the jaws so that they closed in the center and then cut the circle on the BS, and trued it up on the lathe. Then I marked a bunch of circles on it with my skew and drilled them for the buttons.
If I wanted soft jaws I would use my Cole Jaws as a pattern for the chuck holes and drill them. I might glue a second thickness of plywood on to avoid the screw heads. I think you could make these in fifteen minutes once you got going.
Re: Nova Soft Jaws
Re: Nova Soft Jaws
Philip Duffy
>More power to you, Barry. For my impatient mind, the bill was cheap! Let us all now how and how much you enjoy the wooden one. You too, Steve. Philip
Re: Nova Soft Jaws
Re: Nova Soft Jaws
Curt Stivison
>I agree with Phillip. If you guys charge $100 dollars a hour to do turnings you could buy 6 sets of soft jaws and still have enough for a Starbucks coffee.
But that's just me.
CW
Re: Nova Soft Jaws
Steven Antonucci
Account terms: Blue dollars vs. Green dollars :-)
steve antonucci
>If I had a line of people waiting to give me $100 for an hour of my time, then I'd have a real opportunity to make $100.
If I think that my time is worth $100/hr, but no one is willing to pay for it, then I don't have $100.
If I want to have 6 sets of soft jaws with my iced chai latte, then I need to pay a real $100.
When I came out of college, I worked at American Cyanamid. Our logo was blue, and we had the term blue dollars. Things like 2 days of my time in IT cost blue dollars (essentially free), where as a new computer cost capital expenditure $$$. I view my shop time as "free" time since I choose to be in the shop, and I wouldn't expect someone to pay me to take a nap or play with the kids or watch football.
Whenever I can make something (almost regardless of cost) for my hobby, I think it's worth doing. Even if it's a close second, that's not bad. Half of the fun of it is figuring out "how".
Besides, I can get 20 iced chai lattes with my $100...
Steve
Who really wishes that he had thought of $5 coffee...
Re: Nova Soft Jaws
Re: Account terms: Blue dollars vs. Green dollars
Curt Stivison
>Can't put a price on having fun, it's priceless. If you think $5 coffee is something just think if you had thought about selling bottled tap water.
CW
Re: Nova Soft Jaws
JohnKJordan in East TN
>>... just think if you had thought about selling bottled tap water.
I actually thought of that in the '70's: when I found Coke and such too sweet I often wished I could buy canned cold water from the machine. Anyone I mentioned it to just laughed - what idiot would pay money for water?! However, I never once imagined it in plastic bottles.
Re: Nova Soft Jaws
Steven Antonucci
How about Oxygen bars? Sucker born every minute!
steve antonucci
