A55 Smoothing Plane
Lathe Height Question?
>I have my lathe setup so the shaft is at about the height of my forearm if I hold it level. Does that make sense? How about elbow high?
I have a chronic snarled muscle in my back sort of between my shoulder blade and back bone.
I was wondering if the two things are related? I turn mostly bowls and vessels. Would it be better if the lathe was higher or lower?
Re: Lathe Height Question?
RonZ
>Your elbow at center hieght is the standard answer as that is the same thing as your arm parrallel to the ground and your middle finger should be center height.
If the height is correct then it could be tension from using the 'death grip' to hold the tool too tight. You need to be relaxed, both feet flat on the ground, knees slightly bent and work around the piece comfortably.
Steven Antonucci
It depends
steve antonucci
>I have mine set where the legs make it. Most people would consider it low. I think it's high.
It all depends upon what you plan on primarily turning. If I was a bowl turner, I'd want it higher. As a hollowform turner, I'd want it lower to be able to keep leverage on the tools.
Know it doesn't help much, but that's how it is...
Steven
Carole Valentine
>Are you by any chance trying to peer into HFs as you hollow them? That will do it. You can't see anything anyway, so just stand straight and go by feel and sound - or one of those laser thingies if you are inclined to use one. ;) It was a long time before I overcame the natural urge to try and see inside and began to trust my other senses!
>Barry Mine are about an inch above elbow height. That lets me stand more erect and relieved my back pain.
Re: I've not had back trouble...
Allen Neighbors
>since I raised the Spindle height of my Oneway to 49". I had chronic trouble with my shoulders and back until then. I turn mostly bowls and hollowforms on my Oneway. My little Vic is not quite as high, but I do most of my turning on it, sitting on a high stool.
HTH.
Re: PS: I'm only 5'10" tall.
Allen Neighbors
bill crommett in seneca
>Have you considered getting you back fixed ?
I'd have to stand on bricks to be that tall.
Dick Hines
Re: I'd have to stand on bricks to be that tall.
Dick Hines
>My spindle is at 50". I turn hollow forms and bowls and have no back trouble. Now if I spend all day in the shop my knees let me know about it.
At 6'5", 50" is just right for me.
Ron McKinley
>Mine's about an inch higher than elbow height but I often find myself using the "death" grip on dicey cuts. When I finally relax I do O.K......Ron
A turning a day keeps the doctor away.
You still stand tall as a turner & gentleman
Bruce Wiseman
He keeps a milk crate for guests to stand on!
Carole Valentine
Juergen
>I attended a class with Ellsworth last week and here is his take on this question: Elbow height is OK for spindle turning because there in no need to leverage the tool tip since it usually does not extend more than .5-1" over the rest (tool rest is very close to the turning) .
With HFs and bowls the tool tip typically tends to be several to many inches over the tool rest. To counteract these forces you need to place downward pressure on the tool, hence the "Grip of Death" If the tool is at or above elbow height this is hard to do. David recommends if you do bowls and HFs have the tool rest below elbow height, where you can maximize your leverage.
Bill Hale
>It's easy to lower the lathe by just adding height to the floor. If this makes it worse then you know you need to lower the lathe. Each of us turn different in stance and height of the lathe. What ever works is correct for you. Plywood is cheap for floor build up and it has a little cushion for your feet and legs. I use a heavy rubber mat under mine.
Good turning and be safe
Bill in Shopw Low, AZ
russ Fairfield
>Height is a matter of opinion, comfort, and turning technique.
RonZ
>I'm 5'4" and was told I can operate the new Oneway for sitting down....standing up.
RonZ
>I first started using my Vicmarc VL300 at regular height. I went from trigger finger to tennis elbow to my right should in severe pain. I tried a stand/crate but certain cuts and when I was tired, I'd find myself slipping off. I then lowered the lathe into the floor. In Israel we have cement, sand, and then stone/marble tiles. That worked but the knee bar wasn't right. Finaly Vicmarc has made an adjustable VL300. I sold my 'old' one and now I'm waiting for it to get done. Meanwhile I'm using a Wivamac which is about 1" above my elbow at its lowest setting.
Steven Antonucci
When did they take that picture of you, Russ ;-)
steve antonucci
