THE WOODRAT IS BACK!
Green log problems.
Green log problems.
Green log problems.
Peter Hyde
>I have a wood imp that drops off fresh cut logs on a regular basis. Sometimes it means I can't get to them immediately to wax the ends, and in the heat of this summer it meant they were cracking badly after only 24 hours. So the simple solution seemed to be put them in the rainwater butts around the house. A quick phone call and the next batch were then delivered into the butts. Now 2 weeks later I remove them and they are cracked. These were Mulberry and White Oak. So what went wrong?
Re: Green log problems.
Gary Evans Tallassee, TN
>One thing, Peter,
Both Mulberry and White Oak are highly susceptible to cracking. It's entirely possible that the checking you see started before the logs ever got to your place. Also, depending on how they were felled, they could have cracked when they came down.
Gary
Mike Brazeau
>Peter - you need to at least split them down the pith and if possible remove a slice along the pith and then endcoat and keep in the shade. The small amount of end splitting that follows can then be sawn off when you make blanks.
>Don't know about mulberry. As Gary said, white oak is prone to cracking. One of the things that I do to keep white oak "green" for spindles is to bed it down in damp sawdust. But mine is usually rough split into billets (29-30" long) of about 1/8 to 1/4 of the log circumference. That probably wouldn't work for bowls that well.
