Jet mini tool rests
Jet mini tool rests
Jet mini tool rests
Carol - now in NC Nebraska
>While I am waiting on a part solution to the tailstock, I have another question. At Indy Fest there were several Jet mini's. None of the them had the stock tool rest. They all had round bars. Source, cost, reasons for replacement?
Re: Jet mini tool rests
Mini tool rest
Terry Quiram, Roanoke Illinois
>Carol
Those were all welded. Mine are bar stock I bought from ENCO. I usually buy O1 for my tool rests.
Terry
Re: Jet mini tool rests *LINK*
Bruce Wiseman
>Hey Carol,
The tool rest on the Jet mini is the cheapest piece of s... on an otherwise wonderful lathe. They crack, shatter etc. and when they do they leave a razor sharp edge that will cut you before you even know what happened. I think they're some sort of cast pot metal. I once saw three of them break in a class with six lathes. You can get an upgrade from Best Wood Tools or there are several folks that make them. Hopefully one of them will post back to you.
http://www.bestwoodtools.com/
Dennis Yoder
>Hi Carol, It was good to meet you at Indy fest. I got mine from Best Woods at a symposium. I believe that Packard and Woodcraft has them or knockoffs. Best Wood has a web site, google them. I think that they are stronger and provide better control than the standard rest. Dennis Y
Re: Jet mini tool rests - 2nd ?
>Length?
JKJ in East TN
>I'm not sure what you are asking - are you trying to locate an original short toolrest, or a source for a new toolrest? The one I use the most with the mini also has a round bar. I made it one evening from steel I had around, probably about $.50 worth. I made this one extra long to make wands on location since that is why I bought the lathe.
If you weld or have someone near who will, having one made is mostly a matter of finding the proper size steel rods. The Best Wood Tools rests are nice - they fasten together with a screw. Those I have look great, made from brass and steel.
Re: Mini tool rest
>So Terry, you are suggesting I order some of that round stock and have it welded? I think I can find some here to do some welding.
OK, how high is the post and how long is the rest? Another question. Some rests I saw were sort of canted off the post. Comments?
E.T.
>Here is a great new tool rest for mini lathes from Lee Valley tools. I found that the ones that screw together will vibrate when I am working near the end. This one seems to overcome that vibration problem.ET
http://www.leevalley.com/wood/page.aspx?c=1&p=57663&cat=51&ap=1
>Carol I have a welded steel tool rest that isn't round. It's flat, sitting at an angle and about the same length as the jet standard tool rest. It's yours if you think you will need it.
The MountainMan
>Hey Carol
I use the tool bar system from WoodCraft - it has several length rests that attach via a threaded top on the verticle riser of the unit - simple - costs a little more but is reliable and it has a hardened drill rod (which can be filed flat foe accuracy..
Regards
The MountainMan
WoodCraft Tool Rest system
john pickett
>I've had 3 jet mini rests break on me. Woodcraft sells one that is welded steel, not cast iron, but it costs about 4 times as much.
I got the first 2 replaced by jet for free, but I am thinking of getting something welded.
The original
Dave Peebles Lyons, Ohio!
>Hi Carol,
I saw many nice rests at Indyfest. I even borrowed one. But I used the standard rest most of the weekend. It usually works fine for me.
If you have a friend with a welder, some cold rolled steel will work just fine. I also have had some made of drill rod that are really nice for my big lathe. But I never felt like I was close to breaking the 6" rest that come with my Jet mini.
Best wishes,
Dave
eaglesc
>I have made a short tool rest for my casing pens on the Jet out of 2 5/6ths bolts and an HF welder.
That being said I don't care for the round tool rests.For me they make no sense.I like my rest as cloe to the work as I can get it.The diameter of the round stocks prohibits this.
The stock tool rest from Jet and the replacement from Woodcraft work great.
Then again I am not a turner, I only make pens.
tek-Brunswick, Ohio
>Darn it! E.T. Now I that I've seen it I have to order one of those. I notice that it is offset from the post. The other round rests are centered over the posts and sometimes that is in the way.
Thanks for the post.
Tom
Re: Mini tool rest
>Carol
Measure the length of the stock tool post and make all your others the same length. For tool rest length and configuration you can do what ever suits your needs. I had 5 made. A 4", 6", 8",12" and one curved. I bent the rod using a wooden form sawn into 2 pieces and clamping it until it bent. I am plannng to make a J shape for inside bowl work.
Terry
It depends on what you want to do.
Brian Hahn in SW Wisconsin
>I use the standard 6" tool rest for a lot of things. I have a 12" tool rest from Woodcraft that is nice for longer spindle work. And there have been times when I wished I had a 24" tool rest.
Curved rests, which are available lots of places, are nice for bowls. I don't have one since I don't do bowls on my mini.
>Thanks, John.
The rest I have will probably work just fine. I was just wondering why everyone seemed to be using the round ones. Mine was nicked pretty badly but some file work and softening the edge makes it look quite serviceable. Gonna try it for a while until I can better appreciate nuances with other goodies. But I do appreciate the offer.
Ed Heuslein
>Howdy Carol: Well, I gotta throw in my two cents worth. With a mini lathe, many turn small things. The problem with the round tool rests is that they don't allow you to get as close to the work as one made of flat iron. When using very small tools, that's important. I have a couple made by James Johnson (AAW Directory) and love them. They're canted about 40 degrees and allow you to get up close and personal. I'm not affiliated with Mr. Johnson, just appreciate his hard work. -Ed
eliot d
>I would have to say that you are a turner who makes pens.
Re: If you're not... there's
Allen Neighbors
>no such thing.! That's a fact, Jack, and you can take it to the bank.
