Anyone know the strongest epoxy?
Ruth Niles
>There's supposed to be an X6000 or X600 or something like that. It's used to glue glass to metal. Anyone know what I'm talking about?
Ruth Niles
Re: Anyone know the strongest epoxy?
>I've heard of that but can't remember. I have used PC-7 to glue rocks go a wall for climbing. they held a 200lb man. I think that's the same glue they use to glue the reflective dots on the highway
Rocks?
>John,
You glue rocks? Isn't it easier just to use a cliff?
Re: Rocks?
>We put a climbing wall up in the gym. Had to glue the rocks to the cinder block. After 5 years only 1 had fallen off. They took that room over to teach kids so we lost our climbing wall. we even had them on the ceiling in a storage area. We could climb horizontally for 8 feet before reaching the main wall. It was pretty cool.
Barbara Gill, Remlik VA
>Ruth I use E6000 to glue glass to wood; it will glu just about anything to anything. Richard Allen told me about it.
E6000 is not an epoxy I don't think (comes in a single tube).It reminds me of rubber cement on steroids.
Ace Foster in Port Orchard
>I think Barb has your answer. Craft Supplies and probably others recommend this E600 for gluing wine glasses to wooden stems, the reason being that it's flexible enough to allow the wood and glass to expand and contract at diffent rates without the joint failing. I haven't used it a whole lot, but my luck has been good.
Ace
Chuck Engstrom
>Hi Ruth -- For actual strength numbers you could go to epoxy websites like systemthree.com or westsystem.com. 3m's 5200 is a polyurethane with tremendous gooey stickiness but a somewhat slow cure, tho there's a fast cure version out now; it doesn't stink up the place like E6000, and like Brylcreem, "a little dab'll do ya." It cures somewhat flexible but damned tough and is available in most Ace/TrueValue/borg stores.
Best--
Chuck
Steve Russell
>Hi Ruth,
There is a binary epoxy used by most highway departments to glue cracks in concrete bridges and roads that I was told is the strongest binary epoxy currently available. I've used it when we did a plumbing reroute in the slab. It is very strong and mixes like any other binary epoxy.
I would suspect that it is more than you need though, since I don't think you'll be gluing any bridges together. I cannot recall the name at the moment, but if you need it, I will look it up and get back to you. Take care and all the best to you and yours!
Steve Russell
EWW, WVP, EWWFS
E6000 is the one
Ruth Niles
>Thanks, Barbara, that's the one I was told worked best. I need it to glue stainless steel to stainless steel. e, just sent an email telling me the same thing, so thank you both.
If I ever need to glue a bridge......
Ruth Niles
>I'll give you a call for the name of that binary, Steve. : )
Don't think I want flexible
Ruth Niles
>Does the E6000 get hard and not flex? Once I glue the top part to the bottom, I need it to be very firm and solid.
Re: Don't think I want flexible
>It will be a strong bond.
Robin Corell, in Atascadero CA
>Hysol EA9430 is the strongest epoxy I am familair with. I first learned about it when making some high performance molds and we used it to glue aluminium tubing to the epoxy and glass structure. Hysol is one of those by products of the space industry. The bonding strength of the epoxy is actually greater than the shear strength of aluminium and it is good at temps as low as 3 degrees above absolute zero. One of the best properties of Hysol is that is is just flexable enough that it excells at bonding disimilar materials yet its tough and provides a rigid bond in use.
There are many flavors of Hysol adhesive, My coments are all regarding EA 9430 which is the only Hysol producct I have used.
Robin
Re: E6000 is the one
Jorge Castaneda
>Barbara,
3M 5200 rubber is an industrial strength adhesive, but it takes around a week to fully cure, it will join anything to anything, is very thick but cleans easy with paint thinner. I use it mostly to adhere wood to masonry, or metal to wood; once set, it is irreversible, there is no taking it apart. It comes in two colors, white and mahogany.
Maybe is not for your present application, but it is good to know it exist.
$0.02
Jorge
Don Evans
>Ruth:
E6000 is used for gluing materials of two different types, like an inlay of stone to wood. Due to the two materials contracting and expanding at different rates the joint will hold cause it's flexible.
If you are gluing stainless to stainless I would go with JB Weld available at most hardware stores, it's an epoxy with metal in it and extremely strong. I also use Metal Lab in those cases also but it is not easy to come by and rather expensive.
I've used E6000 for over 15 years and it's great stuff and so is JB.
Don
>I should have mentioned that you can buy the Pc-7 at just about any hardware store.
What is your real question?
Brian Hahn in SW Wisconsin
>Do you want the highest tensile strength, shear strength or compressive strength. What about the strength of the bond to the substrate? Are you joining similar materials or dissimilar materials?
The answer can be very different for each case.
So what are you trying to glue together and what are the anticipated modes or causes of joint failure?
The one that holds it all together. :-)
Ray Carson, Lawrenceville NJ
Re: What is your real question?
Barry Elder
>Most slow cure two part epoxies will do what you want to do. But they must be mixed properly. I usually buy a couple of sets of cheap mixing spoons to assure the proper ratio. An engineer at Piper Aircraft told me to use the one-to-one mixes. This is the type of epoxy glue used on aircraft and on spacecraft according to the engineer. I have never had a joint fail on saltwater trolling rods, golf clubs, wood, and it mixes well with filler as it absorbs the color of the filler.
eliot d
>I hope no one will accuse me of trying to hijack this thread; but years ago I bought for a low price one of those really large metal vices whose main shaft was broken right through. The vice actually works, but I thought it best to try "gluing" it together with JB weld on two separate occasions -- both times it came apart again. So we are talking about joining the same metal along a well mated, jagged joint. What do you suggest here?
Brazing!
Jorge Castaneda
>Or silver solder
I agree with Jorge
>Welding, brazing or silver solder.
Mild steel is at least 10 times stronger than even the best epoxies like the one Robin was talking about. For an application like this, you need the strength and toughness of metal.
Re: I agree with Jorge
eliot d
>This vice shaft is 2 1/2" in diameter. Even with welding type equipment, wouldn't it be difficult to get the heat in there? But I'm the first to admit that I don't know anything about welding or brazing. There would be no sideways(shearing) forces on the shaft; only forces along the shaft axis would be in play.That's why I thought some kind of bonding agent might do the trick.
>Now that's a pretty big vise. I know you said big, but that's bigger than I was thinking. I'd try drilling and tapping holes in the center of the rod and using a piece of All-Thread to join it back together. The treaded rod can carry a lot more load than a glue can. If you don't get the holes lined up perfectly (I probably wouldn't), make one larger, tap it for extra gripping power, and take up the slop with epoxy. I'd use epoxy to keep help strengthen the joint and maintain alignment regardless.
