>This is the last one. This is Bradford pear. I hollowed it then cut away a lot of the top. Then painted the inside and the top with black gesso. 5" dia x 4" tall It was an experience. I definitely want a scraper tool for finishing cuts on the inside of vessels. the inside was way to ruff. I finally added some texture to the inside with a wire wheel before painting but would have preferred a smooth interior. Finished with lacquer. Comments Crituques welcomed.
This is a good demonstration of what the inside of a hollow form can look like. Lots of people decide they've put so much work and care into making one, they don't want to cut it open. I think anybody who makes hollow forms ought to cut one open, or in half, especially if its one they think might not be their best work.
If this still had a "grab-able" foot, you could put it back on the lathe and experiment with different ways to clean up the interior. many people are surprised to learn how easy it is to turn a hollow form with cutouts -- I often make cutouts or drill holes to do hollow form demo's.
I use a few different tools for cleaning these up, but this sort of small-scale grooved interior can be tough to fix with a standard Ellsworth-style "bent" tool with a 1/8" - 3/16" cutting tip. With care, I can usually get rid of most of this roughness with light passes to and fro, then I use a Sorby 3/8" bullet-tip scraping tool, most often on a curved, or "goose neck" shaft to make it as smooth as I can. I have 3 of these I got from Sears, of all places. For larger openings like this, I also use the Stewart teardrop scraper for finish smoothing.
I really like the spalted curly Hackberry vessel, but I don't think this profile would do much for me even w/out the cutouts. I'd like it more with a less abrupt change of direction, or a really sharp-edged curve change, but in-between seems a little dull. The Hackberry vessel is a really nice shape, though!
