So I started a fire in the garage last night
Thad Parker
>I had stepped out into the garage to turn a quick spinning top for a co-workers son. Chucked up a scrap chunk of poplar, roughed it round then ensured a nice sharp edge on the gouge and went back to turning it down. Next thing I know I'm wondering what is burning. I shut the lathe off and follow my nose back to the grinding station and find a stray peice of steel wool smoldering bright orange. A spark or three must have found there way to it. That was my lesson learned Tuesday.
~ Thad in Central GA
Re: So I started a fire in the garage last night
Scary, isn't it??????
Ruth Niles
Carole Valentine
>I try to keep steel wool on the other side of the shop from the grinder. That stuff seems to burn a whole lot easier than wood chips or sawdust.
Most steel wool has an oil coating (anti-rust) whi
Gil Jones on Lake Seminole GA
Re: Most steel wool has an oil coating (anti-rust)
Carole Valentine
>Does oil-free ignite just as easily? I have never tried it.
Re:I much prefer the gray Scotchbrite .....
Jamie Donaldson
>...pads to any steel wool, and gray is the equivalent of 0000 steel wool. No metal slivers in your fingers, no rust in light colored wood that still has some moisture, and no fires! I can mount it on a sanding disc (velcro) holder and power buff- much faster and smoother.
>The oil free steel wool that I had burst into flames quite violently. I keep it well away from any sparks and flame ever since that happened.
Re: one way to light a smoke
mike hamilton
>Worked in a juvenile prison for a while in another life. Steel wool was often used to 'pop sockets' in order to light a contraband cigarette. No clue how they'd insert the steel wool into an electrical socket without getting fried.
Regards,
Mike Hamilton
Plainfield, IN
Lan Brady
>Mike,
As a boy scout, I carried 0000 steel wool on all camping trips. Even soaking wet, you can use 2 flashlight batteries and ignite that stuff.
Also, you cannot blow it out once lit. It just fans the flames.
Lan
Re: Batteries- I learned with flint&steel!
Jamie Donaldson
thermite
JKJ in East TN
For even more fun, saturate the steel wool first with fine aluminum powder. Iron oxide works better, but steel wool will still produce an "interesting" reaction and leave you with a ball of molten iron. This is best not done indoors.
(A thermite reaction produces a great deal of heat and was once used to weld railroad rails.)
JKJ, reformed pyro
Brad Vietje
Reminds Me To Ask
Brad Vietje
>Close call on the shop fire -- nice save.
I know people who have burned down their shop, barn or even their house by leaving finishing rags, or soaked paper towels around after using BLO or various oil finishes. Last night I poured some Watco into a clean yogurt container, and from there applied it to a hollow form. I had a little left -- now contaminated after pouring it into the vessel, and back out -- so I didn't return that to the metal can. Instead, I covered the small container with plastic, and figured I'd use it later -- like today. I woke up around 3 AM, and wondered if that was a really really stupid thing to do... Yes ? No ? So far the barn's still there...
Safe spinning,
Brad Vietje
Newbury, VT
eaglesc
>It doesn't have much effect on CA
Re: Reminds Me To Ask
>Brad I'm too scared of fire to take any chances so I lay anything of doubt in the middle of the concrete floor with at least 3 feet between it and anything else. I usually store finishes used or otherwise in glass containers with the lid on. That should keep enough oxygen out of it to stop a fire if it starts.
Re: Reminds Me
>A container of liquid should not be a problem because the oxygen only gets to the surface. Were it otherwise, partially used paint cans would be exploding all over town. Since it is the oxidizing of the oil (chemical reaction) that causes the heat, the barn was OK. Now, if you had soaked up the finish in paper towels and stuffed them back in the cup (thus increasing the oxidizing surface by several thousandfold and adding combustible cellulose fiber to the mix), you could have kissed your shop good-by.
We don't realize that when we put oil finish on a piece, the surface temperature of that wood actually rises as the oil dries and polymerizes. It's unnoticed because the film of oil is so thin that the temperatue gradient is spread out over a large surface that radiates it away. Enclose the reaction on the "surface" of the paper towels or rags with no way to dissipate the heat generated by the oxidation and it won't take long to reach flash temperature and the God Of Fire will pay you a visit.
When you put oily rags in a water bucket, you cut off the oil's access to the free oxigen needed for the chemical reaction. The other solution, as John and I do, is to spread the rag out to dry so the heat doesn't have a chance to build up to ignition. The danger in this method is to think that once the towel is dry to the touch that the danger is over. VERY WRONG!
Oil finishes continue their heat-generating polymerization for quite a while after the surface feels dry. Oil Poly, for instance, can take several weeks or months to complete its cure, all the while generating heat. So, lets all be careful with those "dry" paper towel and rags!!
mm
RonZ
>I found it was too rough compared to liberon's 0000. I use the white pad when I use it on open grain light colored wood like ash.
Re: Reminds Me
Carole Valentine
>I wonder if my method of soaking the towels in water and tying them up in a plastic grocery bag is safe? I don't put the bags in the trash until time for pickup. I leave them on the gravel in front of the shop or in a metal can.
Re: Safe
>Fill the metal can with water or at least enough to cover the rags. Leave them in there until collection day. THEN put'em in the trash when you put out the cans.
You DO have acouple of "ABC" extinguishers in the shop, right?
mm
Keith Tompkins
Re: thermite
keith tompkins
>Magnesium filings left over from machining old vw engine cases burn violently....looks like a halloween sparkler on steriods.
Re: thermite
tek-Brunswick, Ohio
>Are you guys reading the anarchists cookbook or something? Thermite is used in incendiary bombs. Magnesium ribbon is used as a fuse to get the stuff going. Thermite does burn hot enough to melt steel. Nasty stuff!
Chuck Engstrom
>A couple of years ago came I across a couple of 3M pads I had never seen before at Skycraft Surplus (great place!) in Winter Park FL. I liked them a lot, very very fine cut, very flexible, and after some research I found them to be 3M 7745, "Gold" pads. They are even finer than 3M gray -- see attached scan of 7745 box recently purchased from an auto body supply outfit in California, the only place I ever found them for sale on the Net. $30, delivered, for a box containing a roll of 30 pads. This will certainly last my lifetime. The scan shows 3M's own representation of relative coarseness/fineness of maroon 7747, gray 7746, and 7745, plus a corner of one of the actual pads.
I tried to compare them with 0000 steel wool when used on fresh Plexiglass, and as best I can tell, they are as fine or finer. If anyone is interested I can send along info on where I got them -- they are damned hard to find, even on 3M website.
Best to all--
Chuck Engstrom
Re:I'm interested.
Allen Neighbors
Re: thermite
>Someone posted a warning concerning aluminum and steel grinding dust mixed together. It forms Thermite and burns extemely violently. Basically it said i you grind aluminum make sure you have cleaned up all the steel filings first.
Re: thermite
JohnKJordan in East TN
I've never seen any anarchists literature, but my jr high school buddies and I could have probably written our own book about the science and tech of combustion. We were inspired at first in part by the hand-held device in the Wild Wild West show that pretended to burn through steel vault doors. We experimented for years with the exothermic reactions of various chemicals (and metals). Didn't know about the VW engine but you could always buy magnesium from the hobby stores. We went from fizzing to popping to model rocketry with one side foray into jet back packs that fortunately didn't kill anyone. I only set the house on fire twice; Jules' parents banished him early on to a lab in an outbuilding and PP always had the luxury of a concrete garage.
But it might amaze you what you could do with some basic ingredients from the local drug store. (It's also amazing that none of us lost a hand or a face - I absolutely do not recommend this as a hobby!)
It's sad that the way the world is 40 years later, experimenting with such things in the search of scientific knowledge or even good clean fun would likely put you on some sort of suspect list.
Keith Tompkins
Re: thermite
keith tompkins
>John, I could tell you a story about a vw beetle, stuffed with a truck innertube filled with oxygen and acetelyne.
