Uses for a Cone center
Carole Valentine
>What do you all use that big cone center for that comes with the Oneway live center set? I know it must be good for something...I just don't know what yet.
Carole Valentine
Re: Uses for a Cone center
>I just used mine to help true or center a hollow form in the vacuum chuck. I put the drum chuck on the head stock and the cone on the TS with the large end toward the Headstock. I used it to gently press the HF into the chuck. It held it until the vacuum kick in and centered it. Not sure it was essential or even important, but that live center was expensive and I HAD to use that cone for something.
Carole Valentine
>Well, I don't have a vacuum chuck so, maybe someone will come up with another use. That thing must add $35 to the cost of that center set! LOL
Bruce Forrest
>The cone is reversible. ie can be used with either small or large end towards the headstock. Mostly I use it for remounting hollow forms, vases etc and finish turning them. I find it invaluable.
Bill Howatt
>I use it when making end-grain "wine glasses", or other open objects that need support. I hollow the bowl part then bring up the tailstock with the cone and insert it into the bowl until it just provides some support. I can then work on the stem or whatever without any whipping.
Handy tip is to put a suitable-size cheap plastic funnel with the sharp end cut off over the cone. These keeps black aluminum oxide from being transferred to the wood.
Bill
>Carol I've used it to center spindles with large predrilled holes. I also had to re-turn some defects from a damaged hollow form. I was able to use this center in the open end to center it up. I turned a rebate in a waste block for the bottom of the form.
Re: Uses for a Cone center------WebKitFormBoundary
Phil Powell------
>We've used it as a dunce cay on our gerbil.
Norm Smith in Nova Scotia
>Carol, I also use mine for things that the others mentioned. I sometimes put a tennis ball in the cone while reversed on the TS to support a vase or hollow form that already have the opening finished.
Norm
Use it for turning spheres
Brian Hahn in SW Wisconsin
>The easiest way to turn spheres is with cup centers. Use the cone as the tail stock cup center. The picture below shows an incised sphere between cup centers. My live center is a Nova, so I was able to make custom cup centers, but your Oneway cone should work. That sphere is one I made last week, I'm turning stands for the spheres tonight.
gary s clarke
>I use a cone center to center rings for glue up on segmented bowls. I have a larger one that I use for larger rings. I bought the larger one from Curt Theobald. Both work well.
Carole Valentine
>OK, now I have a few ideas. Thanks!
learned something new
Atwerz
>Brian every time I log on I learn something new. Your tool rest is turned around flat side out. I never thought to use it that way. I don't know why I do things backwards or the hard way.
I was wondering if someone would notice that.
keith tompkins
>Carol, another use is for making thin stemmed goblets. Turn the goblet section, then use the cone to steady the opening. Then, turn a thin stem without worry. Works great.
Bruce Said What I Was Going To Say
Ric Taylor
Barry Turner
>I'm sure that thing has uses in turning pepper mills. (I've never used mine either!)
Carole Valentine
>That's the only use I have made of it, Keith. :)
