Buying turning blanks question?
Alan Tolchinsky
>Hi All, I haven't been here for awhile but I'm trying to get back into turning and thus my question. I see a place online that sells "green and waxed" blanks. I have no idea of the moisture content. What do you do to turn these? I normally would rough turn then let dry. Would you seal with anchorseal etc. or wrap in paper? Any ideas greatly appreciated. Alan
Re: Buying turning blanks question?
GaryG in MD
>Welcome back to turning, Alan. There are a large number of sellers of wood online. The wood may be anywhere from relatively freshly cut to kiln dried. If it says it's "green and waxed", it will be anywhere from weeks to many months from having been cut. Be very careful to make sure the seller is showing you a photo of the exact piece of wood you are purchasing -- not just a "typical" one. Look carefully at the seller's philosophy regarding cracks. Some will replace a cracked piece (unless the text says something to the effect that it may be cracked), while others say words to the effect that cracks add character, and they are not responsible and don't care. FWIW, I've had very good luck with Gary Davis at NCWood.
Regarding your primary question -- you treat it just like any wood you cut and wax yourself. Depending on the type of wood and its size and shape, it may last a long time without cracking, or it may crack as soon as you look at it. You takes your chances. I recommend processing the blanks like you would if you had cut and waxed the wood yourself. You can go thin, direct to final form or you can create a thick roughout for drying and returning later. If the latter, the drying process may range anywhere from burying in wood chips, more wax, or paper bags, to boiling, soap, microwaves, alcohol, or whatever. All of these approaches are documented in the Archives.
Have fun and good luck, Gary
eliot d
>I admit that I sometimes use purchased waxed wood. But if you really want to do it right, it's better to get section of a log. That way you can judge much better what your piece will look like before you start turning. It's all a matter of grain orientation. The best description of how to go about it that I've seen is in a DVD by John Jordan.I can't remember the title, but others will, and it's probably one of the best things to learn about woodturning. If you keep using pre-cut blanks, you will be forever guessing how things will come out.
Alan Tolchinsky
>Thanks Gary and Eliot,
Those are great tips. I'm looking at blanks from Gary so it's good to hear he's reliable. I'd love to find my own wood but in the past it just got to be too much with hauling and using a chainsaw. Although I loved to do it, my back didn't like it too much. Thanks again. Alan
Hey Allen
Gerry Meekins
>Hey Allen,
Good to see you are back to turning.. By the way, there's an excellent turning club right down the road from you.
(Assuming you are still in Potomac). eliot d could tell ya all about it too...
Take care,
Gerry
yup
GaryG in MD
>Gary Davis at NCWood is one of the good guys. He sells a good product, and if you have any problem with it, he'll make it right. Guaranteed.
If you're indeed living in Potomac, please join us in Rockville on October 11 as a guest for the next meeting of the Montgomery County Woodturners. You can check us out at http://montgomerycountywoodturners.org
Brian Butters will do the demo. You can check him out at
www.butterwood.biz/main.html
...Gary
