Finally buying a drill chuck for my lathe
Michael Stadulis, in Gloucester County, NJ
>Here's my question. My tailstock has a #3 MT ......while the headstock has a #2 MT. I don't know how unusual that is. Will I find a need to use the chuck on both ends of the work? I was figuring on mounting it on the headstock, but who knows...... I could always order it with another #3 MT arbor and have the arbor handy so I have more flexibility.
Your advice would be appreciated.
Mike
Re: Finally buying a drill chuck for my lathe
Bruce Lane
>I would buy both.
If I am drilling a pepper mill, my chuck is in the tailstock. If I am using the chuck to hold a mandrel for a bottle stopper, the chuck is in the headstock. Just 2 examples...
Bruce
Nelson
>I use mine 99% of the time in the tailstock, can't remember last time I used it in the headstock.
Ken Grunke from SW WI
>I use a jacobs chuck in the headstock once in a while. If you use it as a workholding chuck, such as for bottlestoppers, it should have a drawbar. Otherwise, I just tap mine in lightly with a mallet and most of the time it's OK but I never use it for a wood chuck, only for drilling.
Barbara Gill, Remlik VA
>I bought the #3 MT and the Jacobs Chuck from Grizly. I then heated the Jacobs chuck and quickly hit the #3 MT home into the chuck. Works like a charm
>For using your chuck on the tailstock Oneway makes a Live Center Spindle Adapter. I use mine all the time.
Chuck Engstrom
>Places like MSC and Enco sell adapters that would let you buy a chuck with #2 taper and use a 2MT/3MT adapter to mount it in the tailstock. You can buy the chuck from them as well; they carry lots of this sort of stuff.
Best--
Chuck Engstrom
Allen Neighbors
>Michael, like Chuck advised, I have a Drill Chuck with a #2MT, and I bought a #3 to #2 Adapter, so I can use it in my Oneway Tailstock. I can use it without the adapter in the headstock. It's easier to add and remove the adapter than it is to change tapers in the chuck.
The only thing that would be easier than changing adapters would be to buy two chucks... one with a #2 and one with a #3.
Thanks for your help, everyone. Much appreciated.
Gary Evans Tallassee, TN
>Hi Micheal,
If you haven't already bought your chuck, you might check out Mike Hare at VM Woodworking vmwoodworking1982@yahoo.com.
He sells a very nice keyless chuck with #2 taper for $38. With #3 taper is $5 more. Everytime I see them I covet one, but have other things to spend money on first.
I agree with those who suggest buying the chuck with one taper and then getting an adapter for the other. If you clean the taper and socket as recommended and then seat it properly, you won't be able to change it out very readily.
Gary
eliot d
>Chuck, I presume you mean a bar that comes through the spindle and attaches to the (left) end of the Jacobs chuck and then somehow pulls it toward the headstock so the chuck doesn't spin out of the spindle. Does this mean that there is always a way to attach such a draw bar to the chuck morse taper? I have a morse taper that holds cloth wheels for buffing, and it often spins out of the spindle. Where do you get these draw bars?
Usually not, so you probably have to drill and tap the arbor's small end yourself. 1/4-20 All-thread rod from the hardware store is good enough for a drawbar with a nut and a big enough washer on the outer end to bear up against the spindle's outboard end.
eliot d
>Thanks. I get the idea.
