Behen & General salid bowl finishes?
Norm Smith in Nova Scotia
>Have any of you Guys or Gals had any experience with Behlen or General salad bowl finishes. If so, what are the pros and cons?
Thanks,
Norm
Thanks,
Norm
Re: Behen & General salid bowl finishes?
Allen Neighbors
>Norm, I've used it before, and it seems sticky when it's applied. I don't know if I'm doing it right or not. I may be letting it set too long before wiping it off, or not long enough.
I'd much rather use a lacquer wash (35/65%)before sanding, and then apply either Danish Oil or Antique Danish Oil.
If I'm right, it has to be food safe when cured, anyway.
Maybe someone in the know will chime in. ...perhaps Russ...?
Claudia Hayward
>Norm
I've been using the General salad bowl finish for quite awhile and really like it. I'm using mostly maple (the bigleaf, softer than yours). The first coat really soaks in so I'm really generous with it. Coats after that pretty much build up the surface. The trick is to be sure to stir the can before you apply (DAMHIKT), put on a relatively thin coat and wipe off pretty much immediately. If you find it's going sticky on you then you left it too long. I generally leave it for 24 hours before applying the next coat and sometimes have left it for 36 if it is still a little tacky after 24. Depending on how many coats you put on you can get a satin finish or a fairly glossy one. BTW, and I haven't tried it- Watco has a new salad bowl finish out, I saw it at HD with the Watco products. Don't know if Rona will have it in their Watco dept.
Good luck...
Re: Behen & General salid bowl finishes? *LINK*
russ Fairfield
>All oil finishes are essentially the same, and some combination of an oil, thinner, sometimes either natural or synthetic resins, and usually drying agents to make them cure faster.
Cadmium and Lead are forbidden by Federal Law. Other than those two ingredients, almost anything is permissable.
The thinners are the problem, and once they have totally evaporated, the remaining polymerized finish is inert.
There is a suggested process for extracting the oils and mixing the ingredients into the finish and a testing procedure to insure there is neither Lead nor Cadmium in the finishing product. All finishes have to las the Lead and Cadmium test. Some just like to label their product as somehow associated with the FDA Regulations, and for that, you will have to pay extra.
That's the short version of a longer discussion on my Website.
"Food Safe", What does it mean??
>Thanks Guys, I appreciate your response.
Russ, I have looked at your information on Wood Central. I have printed some of it off. It is great information. Thank You.
Norm
Allen Neighbors
>Thanks for the info, Claudia. I'm gonna try it again, and see if I can follow your instructions. I was pretty sure I wasn't doing things right, but didn't know which. :)
I don't like a heavy, built-up finish on bowls, so I'm going to stir the heck out of it, give the piece a heavy, penetrating coat, and then wipe it off... before it gets sticky.
