Finish for yew????
Finish for yew????
Mike Stafford
Finish for yew????
Mike Stafford
>My son sent me stick of yew from England for Christmas and I was turning a piece of it and I thought, "What is the best way to finish yew?" And my self said, "I don't know".
I turned some a while back from a local source and finished it with oil/varnish and the white sapwood yellowed badly.
Any thoughts?
Re: Finish for yew????
Polish????
Gil Jones on Lake Seminole GA
>Mike, I have not turned Yew, but when in doubt of the best finish to use, I sometimes just polish the wood, and add a bit of hard wax to see how that works. It does work well on Cedar (Juniper).
Gil
Carole Valentine
>Mike, Yew is an evergreen, right? Try several coats of thinned lacquer and then buff to satin. You know the drill in between coats. Or, you could use one coat of thinned lacquer to seal it then go with oil.
Mike Jones
>I have turned a lot of yew and if yours is anything like our Coastal yew from the Pacific Northwest, you should get excellent results from most of the traditional finishes. If you turn it (very and evenly)thin, and with the pith along the center axis, you'll find it to be very stable. The sapwood seems to stay white, and the heartwood mellows to a rich orange/brown.
russ Fairfield
>Yew is one of those woods that look better with nothing on it. Sand to 600, make sure there are no scratches, and leave it alone. You can always put a finish on it later if you don't like the way it looks after it ages. Do it now and you will have missed the chance to appreciate one of the most beautiful of natural woods. (My opinion)
If you have to put something on it, minimal is best. One sloppy coat of lacquer, and wipe it all off to dry after waiting a couple minutes for it to soak in, is all the finish it needs.
Mike Stafford
Mike Stafford
>Carole, I don't know if yew is an evergreen or not. I will have to ask my son.
Mike Stafford
Mike Stafford
>Mike, this stick of wood appears to be kiln dried and does not have any pith in it. It is very dry and screechy as I get thinner and thinner.
The other thing I have heard is that you have to be careful how thin you turn the end grain as it is prone to checking, right?
Mike Jones
>If the wood is bone-dry, I would expect no more checking than is present now, as it would be stable already. And, if dry, I wouldn't be too concerned about turning it super thin...for the same reason.
A word of caution: yew (taxus brevifolia) contains the toxin paclatoxil. Be especially careful of breathing sanding dust, and if you 'buff only' as suggested by Russ, I woulod not consider it to be food safe.
