laser light holder
laser light holder
laser light holder
olejon10
>my laser light going out all time so I bough new laser light the new light is bigger than the old one and will not fit my holder (I have the lyle jamison hollower)can anyone tell me were I can find a new holder thank you
Re: laser light holder
>I bought the same setup from Lyle several months ago and just got around to setting it up. Within minutes the laser was flickering and going dim. (See my post about the batteries, down about a page)
The folks that responded there said the batteries should last tens of hours which would be weeks or months for me. One person suggested a stronger spring to keep the batteries pressed firmly in contact during the vibration. I wonder if the spring could be moved from the bottom to the top so that it would have gravity working for it?
A couple of asides. There is remarkably little information on the package about who made the laser. (CE, Are they a company or a testing lab like UL?) If you lost your box I can search mine again. OTOH, I doubt you want to replace yours with an identical one, probably something "better" if such a thing exists. Oddly, while trying to put mine int he holder the label wrinkled and began to peal off. I finally took it off only to discover there was another one under it with a completely different number on it.
I bought one recently form Office Max. They had several, but I am not sure whether any were this slender.
When I went to Lyle's demo, I distinctly remember him saying he had chosen this laser because it was tough enough to do the job. You don't suppose it was the only one slender enough to fit the hole?
And while I am griping, I wish that clamp that holds the laser had an X/Y adjustment on it that was easier to use. Two knobs that moved it left/right and in/out sure would be handy. Lyle claimed he spent thousands on the molds for the plastic parts. Seems it did not occur to him to make it a little more user friendly. Don't get me wrong, I will "get used to it", but for the kind of money I spent on this thing I could have bought a lot of other tools that were slicker and actually "manufactured". I could have pretty much cobbled this together myself. Not sure why I didn't.
I am going to try finding a better spring for the laser or perhaps a small piece of metal to take up a little of the space.
One more thing, I played with the different lenses that came in the box. One of them puts a circle around the dot. Wonder is you could use it by putting the dot exactly on the tip and then watch the circle? That way you would not have to keep moving the dot.
