Desiguse a mess
Desiguse a mess
Desiguse a mess
eliot d
>I just turned a hollow form from (I think some kind of maple). It's not the worst shape, and it was a fair amout of work to hollow it out. But it has numerous cracks that I filled with CA glue and sawdust, which left the work with ugly yellowish stains, and the wood has lots of ugly grey stain all over it. The cracks don't bother me me much, but the stains do. I tried bleach , which did lighten the mess somewhat, but it didn't even out the color. Last Saturday I saw a demo where a black leather dye was used to give the work a beautiful black luster. Could I salvage mine with something like that? Otherwise this one is going in the burn pile.
Re: Desiguse a mess
Re: Desiguse a mess
eliot d
>Sorry. 'DISGUISE'.
Re: Desiguse a mess
Re: Desiguse a mess
Don in Central Illinois
>I was glancing at a back issue of Woodturning Desigin (I think) and they had an article about painting the HF and making it look like clay. When I get home this evening and remember, I'll try to find the article so I can at least give you the month of the issue.
Re: Desiguse a mess
Life is Too Short To Turn Crappy Wood
Wally Dickerman in Arizona
Re: Desiguse a mess
Life is Too Short To Fix Crappy Wood
Ron in Drums PA
>Whatever you do will look like.. well. ...like you tried to fix a problem.
Chalk it up to experience and get started on another block of wood.
Re: Desiguse a mess
Re: Desiguse a mess
Rick Allen
>Hi Eloit
The beauty of dye is that it lets the grain of the wood show through. Well the cracks and stains are also very likely to show through.
Paint or metal leaf will hide the "mess". But then the piece doesn't much look like wood.
Good Luck
Re: Desiguse a mess
Re: Life is Too Short To Turn Crappy Wood
Tim GC
>Here where I live if a tree isn't a pine of some sort it has a preservation order on it. You need at least 3 reams of paperwork and a six month wait just to de-limb anything. So, unless I want to turn pens or buy dried bowl blanks from a retailer, I have to make the most of anything I can get my hands on!! Even turning 'crap' can sometimes be better than dying sat in front of a TV!!! Besides 'crappy' wood can make for a serious learning curve in methodology and technique. I cannot even remember the last time I had the opportunity to turn a wet piece of wood.
Re: Desiguse a mess
Re: The dye will not penetrate....
Jamie Donaldson
>.. areas where CA was used, so experiment. Sounds like you have little to lose, so go for something you've not tried before and gain from the experience.
Re: Desiguse a mess
Re: Desiguse a mess
Mike Jones
>I'd say set it aside for awhile. The solution might come to you after some similar experience, a demo, or magazine article. Sometimes I just have to get away from a project for a bit. Inspiration hits and away I go again.
Re: Desiguse a mess
Re: Desiguse a mess
>Leather dye won't penetrate where the CA glue is but might color it anyway. It depends on the brand. Usually where the CA glue is will look glossier which doesn't look good. A better choice would be paint. The cracks may look wierd so I often will add a textured area that butts up against the crack. This looks more natural.
I use a Dremel engraver with a rounded over point but you can also use a standard dremel with a round ball or a woodburning pen with a ball tip. You can even take a 3 /32 nail set or a leather tool and just stamp that area.
You can try the leather dye. You can always paint over it. If you sand good first you might sand through some of the CA and it won't look as bad.
Re: Desiguse a mess
Re: Desiguse a mess
russ Fairfield
>You will be surprized how well things look with a coat of the flat-black BBQ paint.
The only problem is that the black accents the form, both good and bad; the wood surface has to be smooth and free of sanding scratches and tool marks because the flat black will accent every flaw; and any spots of CA glue will show up as a higher gloss.
Sometimes it is best to give it up and write it off to experience.
Re: Desiguse a mess
Amen!
Barbara Gill, Remlik VA
Re: Desiguse a mess
Sounds like you need to move!!
Bruce Forrest
Re: Desiguse a mess
Re: Sounds like you need to move!!
Tim GC
>Most of the UK is in the same position. There are areas which have a better spread of species /genus or whatever, but unless you own a forest or know of someone who does, or maybe have a pet tree surgeon then retail blanks are just about your only option!!
Re: Desiguse a mess
Steven Antonucci
Save it for experiments
steve antonucci
>I keep those "offish pieces" for trying out new techniques and eventually either "fix" them or burn them. Try painting, burning, carving...
Steven
Re: Desiguse a mess
Ric Taylor
Re: Desiguse a mess
Ric Taylor
>elliot,
I can't help with this piece, but here's what you can do in the future to avoid this situation. It sounds like the worst part of the problem is the stains left by the super glue. The next time you have to put super glue on your project, before you do that, saturate the entire piece with a 50/50 mix of lacquer and lacquer thinner. Let it dry, it only takes a few minutes, then put the super glue in the cracks. The lacquer will seal the wood, preventing the super glue from soaking into the surrounding wood and causing the stains. After the glue has dried in the cracks, continue turning and sanding as usual. This will keep the wood from staining and it will not effect your finish.
Ric
Re: Desiguse a mess
Re: In addition to Ric's post...
Allen Neighbors
>even after the lacquer mixture, when you sand it well, it will still take a Danish Oil finish if you like.
Re: Desiguse a mess
Re: Desiguse a mess
Peter Hyde
>Here's a suggestion. Forget the sanding just put it back on the lathe and use a gouge to put some tool marks on it and then scorch it all over with a propane torch. A coat of flat lacquer and you are done!
Just like this
Re: Desiguse a mess
Re: Desiguse a mess
eliot d
>Rick, I don't usually print out responses, but I did print yours out so I won't forget it. Thanks.
Re: Desiguse a mess
Re: Desiguse a mess
eliot d
>I printed out your response , as well. I plan to actually try your method. Thanks.
Re: Desiguse a mess
Re: Desiguse a mess
eliot d
>I suddenly recall a Richard Rafan video in which he burned a box he made, and it came out so blotchy and awful that he had to re-turn it. Are there some tips you can give on burning with a torch?
