Split turning
Split turning
Split turning
Gary Smyth
>I have to prepare a stacked series of wood "plates" that once turned to a round will be separated into donuts, then bored to form pockets for legs to fit into. They will be used simply to capture the leg and keep it from wandering when the platform they are installed on is pushed around.
My problem is that I want to turn the six pads at the same time. My intention was to split turn them by gluing the six 4 1/2" square pieces together with paper between the pieces. Mount them in the lathe (using headstock and tailstock) and turn them round to a cylinder, separate them at the paper line, bore them for a 2" leg and then mount them to the platform.
My problem is that most split turnings I have seen has the glue line parallel to the lathe bed, as for a column, not perpendicular, like stacked wood on its side as I want to do. I should probably have turned the cylinder first then cut the pads but I wanted no warping, or glue line, and didn't have the thick stock. My solution was to cut the pads first and now I want to glue them for eventual release and turn them. Does anyone have experience with split turnings? Can I safely turn with the glue line perpendicular to the lathe bed? Will the glue and paper hold? Several turning books I have offer no help. I can get the stacked pieces to at least a octagonal shape on the table saw, so the cuts will be light.Anyone ever do this?
Re: Split turning
Re: Split turning
Brian Hahn in SW Wisconsin
>Back in the old days before scroll chucks, a standard method to hold a bowl blank for turning was to glue it to a block on a face plate with a piece of paper in the glue line. The advantage was no screw holes in the bottom of the bowl and you could use the entire thickness of the blank. The disadvantage was cleaning the blinking paper off the bottom of the bowl.
In other words, no problem gluing up a stack of blanks like you plan.
Re: Split turning
Re: Split turning
>You can do that quite successfully however you may not need to glue them. If you have a hole in the middle you can simply stack them up using a dowel or other means to hold them together. I've done it a lot of different ways.
One method was to use a dowel through my tailstock and into the headstock. My tailstock has a 3/8" hole. I center drill a 3/8" hole in each one. I use a cup center to press the discs together and push into drive center. Then turn them and pull them off.
Method two. I cut an X in a piece of all-thread and center drill the to other end. Drill the wood for the all-thread. Place the pieces on the all-thread with nuts and washers to hole them toghether. Then put the all-thread between the drive spur (which fits in the X) and the tailcenter.
I have glued them together with a paper joint but removing the paper can be a hassle. I've sanded it off but this leaves sanding marks, may not be flat and ruins your sanding belt. Scape it off with cabinet scraper. Works good but it's easy to tear out a chunk of wood on the side grain. White Vinegar will dissolve white and yellow glue and you still need the scraper but it comes off much easier. Very messy.
Cloth backed double stick tape is better. It's easier to remove because you don't need as much. Mineral spirits will soften it for removeal if you can't get it off. To seperate the discs take some fishing line or thin wire and simply pull it between the discs.Do this with the lathe turned off. This will sort of cut through the tape and pop them apart.
