>a Newton Balancing Vessel? Does anyone have a picture of one?
I heard this being discussed at the store and from what I gathered and from the sketch I saw it is like a hollow form where the bottom comes to a very sharp point and stands on a little pedestal or base perfectly balanced. I am curious about this. Anyone know anything about such an animal?
>I've just never heard of it called a Newton Balancing Vessel. There have been several (marginally successful) attempts to make large parabolic telescope mirrors out of vats of spinning mercury. This was before the technology existed to cast and support large glass mirrors. I helped a friend make a 4' parabola by putting a layer of melted wax on a spinning vat of water and waiting for it to cool. He then covered the wax with tin foil. I don't know if it worked well as a solar reflector, I imagine it warped as soon as it was in the sun!
If you find a way to apply idea to a piece of work let us know! You never know where inspiration will come from.
You reminded me of something I haven't thought of for years. When I was about 12 or so I also made a 4' parabolic reflector using tin foil as the surface. I formed the surface by cutting parabolic curves from corrugated cardboard, arranging them radially as webs, then gluing cardboard wedges to the top and covering with foil to form the reflecting surface. The focal point was pretty sloppy from the surface irregularities, but it could easily boil water.
A few years ago I found myself working again with parabolic solar reflectors. At ORNL,we developed a hybrid solar lighting system which pumped light through fiber optics into a building. The system contains a mechanism which keeps it pointed at the sun throughout the day. We started development with a $10,000 glass mirror with the latest design sporting an inexpensive plastic mirror. BTW, for playing around you can get pretty good results by covering an old communications dish with foil.
Link below on the HSL program at ORNL if anyone is interested.
>Based upon the description and sketch I saw this is a hollowform in the shape of an old throw top where the bottom comes to a very sharp point and balances on a short pedestal or stand. Or it is the illusion of a hollowform shaped like a throw top balancing on a pedestal or stand. As I said I have not actually seen one but obviously someone has taken this physics example and used it to name an object they have turned.
I was just curious if anyone has seen any turning reminiscent of this....
