LOML problem
LOML problem
LOML problem
eliot d
>If you guys are honest , you'll confess as to whose the boss. The LOML had a fit when I told her I was going out to but this guy's HF metal lathe( he had done numerous modifications on it and was selling it cheap). She was sure it would make a terrible greasy mess combined with metal shavings that would get in all the clothes and that I would track all over the house. ( She also said that the HF was a piece of junk and that if I were going to ruin the house, I should get a real metal lathe!) Is it really messy? I thought the metal shavings, being heavier than air,would more or less stay close to the lathe and that I could just clean up after each session.
Re: LOML problem
She's Right!
Ron in Drums PA
>Geesh! What the problem!
Go get a real metal lathe, just like she told you.
Re: LOML problem
Re: LOML problem
>Metal shaving get everywhere. They are harder to get out of your clothes that wood as well. As far as grease and oil. Well I'm afraid that's true also. I just got a Smithy last year and I'm kind of a clean freak. Keeping the shop clean of that mess is definitely harder. When I work on that machine I pretty much assume that I'm going to get oily and dirty, and I'm not even using a coolant.
Re: LOML problem
Re: LOML problem
Ed in Leaside (Toronto, Ontario)
>Ok, so the metal chips are heavy and fall straight down (exceptin' when they're springy and bounce all over the place). As you stand and work at the lathe, you're standing on, and working into your boot soles, bits of metal that'll have to be pulled out before walking around the house. Sure you can change shoes but you'll find that as you do so, the chips have a tendency to migrate (kinda like dog-to-dog flea transfer).
That being said, I've done a fair bit of metal turning on my wood lathe in the last few months. It can be interesting, if somewhat tedious, but turning wood is much more fun (and less messy).
Re: LOML problem
Just wait til you walk in them and then
Ray Thompson - Middletown,IN
>walk on her clean carpet. Wear armor.
Ray
Re: LOML problem
Re: LOML problem
Doug Thompson near Cleveland
>Like Ed and Ray said shoes stay in the shop... period! Use a magnet to help clean up the chips. Last word of caution, keep your mouth shut when using it, nothing worse than a hot chip in there.
Have fun with your new toy. Ebay is a good place to look for tooling
Re: LOML problem
Richard Allen
Re: LOML problem
Richard Allen
>Hi Eloit
I have met your "SWMBO". She didn't strike me as someone who would know about metal lathes or about HF making less than high quality stuff.
The fact that she knows this "stuff" helps to show that she is truly a remarkable person and you should pay close attention to her sage advice.
If you want to turn metal you should develop a friendship with someone who has that sort of equipment.
Never forget what is really important.
Re: LOML problem
Re: LOML problem
Ken Oakley-Sunny St. Cloud, Fla.
>Always wear your shirt outside the waistband of your pants if not wearing an apron. Those chips and shavings are hot and can burn some critical parts if you don't. Been there-done that.
Re: LOML problem
Eye Protection
jwoodwright
>This is one area it's not Optional. Emergency Rooms have Magnets to help remove the Iron and Steel bits from the Eyes. Aluminum is another story. The Cutters you use have "chip breakers" ground in or else you make steel wool.
