A different kind of Steady Rest
russ Fairfield
>I have been using 2 of the Oneway Bowl Steadies to make a steady rest for things up to about 12" diameter. This arrangement works better than anything else I have used for this size range.
russ Fairfield
Re: A different kind of Steady Rest
russ Fairfield
>The piece in the previous picture has a lot of missing wood, so there is a ring glued to it to hold it together. The ring was turned away after the piece was hollowed.
Eddie Pacheco, San Jose, Ca.
>Do you move the steady rest toward the headstock and support the piece there while you turn away the support collar? Very nice setup, Russ.
Carole Valentine
>Well you just answered my question on the other post. How did you fit the ring? Make the ring first to the diameter you wanted for the goblet, then turn the goblet until it fit? What kind of glue? The piece is so darn thin I would think the glue would have penetrated enough to leave a stain when the ring was turned away, but obviously it didn't.
I'm curious too
Ron in Drums PA
>Great idea Russ, thanks for sharing that with us.
I'm also surprised that the glue didn't stain the wood. How'd you do that?
Bob Way, Canton, MI
>Your timing couldn't have been better. Thanks so much for what may very well work out to be such a good and clever solution to a situation I've been trying to work out some solutions for.
Bob Way
Canton, MI.
Re: The glue.....
russ Fairfield
>I used Model Airplane glue, available everywhere as "Duco" Cement. This stuff is nothing but a thick nitro cellulose lacquer, and since I was going to use a lacquer finish, there is no stain to worry about.
I turned away most of the ring between centers, and them removed the remainder with a sanding disc when it started to get too flexible to turn. The ring was made from White Pine, so the sanding was easy.
Thx
Ron in Drums PA
Thanks, Russ
Carole Valentine
Not too shabby!
Dominic Greco in Richboro PA
>Russ,
I sure wish I had that rig on my lathe this past weekend! I had a huge piece of cherry on there that was too big for my 3 wheeled steady rest. It was like this, "Cut, Cut, Cut, DUCK!!!" as it came flying off!
See ya around,
Dominic
