Best wood tools
Best wood tools
Best wood tools
>I visited Vic and Sharon of bestwoodtools today. Had a good time. You really have to want to go there they are way (I mean way) out in the boonies. I'd buy property there in a heartbeat if I could afford it. It's great country.
Anyway I learned a few interesting things while talking metal with Vic. The first was that his tool rest are made from a special steel designed for NASA to reduce vibration. He said he tried stainless which vibrated horribly and several other steels until settling on this one. You'll still get some vibration of course when you get out to the ends but I've always found his tool rests to be excellent. I use the 9" offset one constantly. This is also why he uses brass inbetween the post and tool rests. It is the best material he cold find to reduce vibration.
We talked about hardening tool rests. He said he doesn't do that because he feels a tool rest should be softer than the tools. He said your tools cost 40 to $100 or it would be better to file or sand dings out of the tool rest than the tool.
My one complaint with my tool rest is that when I slide my hand down the tool rest in hits the tool post and causes a little bump. This is common with all the round tool rests. My tool rest is 3/4" in diameter. Vic suggested I get a 1" tool rest. I think I'll that when I get some spare cash.
I went to pick up one of the Baxter threading machines that I ordered a while back. It is incredibly smooth. I can't wait to try it tomorrow. He's redisigned it slightly. He found out that there would be problems in some parts of the country due to the different movement of the metals. This only happened on a few machines and he's sold over 500. He did some research and found some brass that matches the same expansion as his aluminum. This eliminates all slop in the screw thread parts. I really appreciate fine machinery and this is certainly one.
It's always fun visiting them and I usually learn a bunch.
Re: Best wood tools
Re: Best wood tools
Ruth Niles
>I use the Bestwood tool rest and after your explanation, now I understand even more why I love it. Sharon and Vic are very pleasant people and I like doing business with them.
Re: Best wood tools
Re: Best wood tools
Larry Bisbee
>I purchased my Baxter threader several years ago from Willard Baxter after watch him demo turning and threading an acorn box. It too was made by Best Wood Tools. The Baxter Threading Machine is well made and easy to use. I have several of the tool rest made by Best Wood Tools as well as several of there other tools and have found them all to be well made. I always look forward to seeing Vic and Sharon at the symposiums held here in Georgia and I always check their booth for new additions, that I absolutely must have to have, for my woodturning tool collection.
John, thanks for all the info. Now I know why I like buying and using their tools. I know you�ll enjoy your new Baxter Threading Machine and will put it to good use.
Re: Best wood tools
Re: Best wood tools
Allen Neighbors
>I got absolutely awesome service from them when I ordered my Spindle Adapter for my Oneway. Three days, if I remember, and that's good for this part of the sticks!
I didn't realize how much runout I was getting with it though, until I got my little Vicmarc lathe. The same chuck, mounted on the Vic has absolutely no runout... (not a bit of shadow) but mounted on the Spindle Adapter on the Oneway I get runout that I can see. When I reverse a piece I have a rough time with the bottom, and didn't realize how rough, until I reversed a piece on the Vic. It's as smooth as silk. It has to be the Adapter. Now I'm leery of purchasing another.
Re: Best wood tools
Re: Best wood tools
>Interesting. I would contact Vic and talk to him about it. I have a 1 1/4x8 to 33.5 that I got from them and it runs absolutely perfect.
Re: Best wood tools
Re: Best wood tools
Doug Thompson near Cleveland
>OT - John, you own a powermatic...
Re: Best wood tools
Re: Best wood tools
>Doug I needed that when I travel and demo on Oneways. It's 33.5 inside and 1 1/4x8 outside to fit my chucks. I have adaptors for the chucks to fit all the smaller lathes. I think I bought that when I demo'd at the AAW in Florida. I didn't want to get there and not be able to use my chucks. Oneways are getting more and more common for club demo lathes.
Re: Best wood tools
Doe sit have a set screw
Mike Brazeau
>Allan - does the Best Tools adapter have a set screw? I have an adapter to go to 1" x 8 from Oneway for my 2436 and I find it really touchy on the set screw setting. If set too firmly it creates runout on the adapter. Back off on the screw and it goes away.
Re: Best wood tools
Re: Best wood tools
JKJ in East TN
>J.Lucas,
Thanks for the info. I always liked the round tool rests I got from them and now I know at least one reason why. (And why the one I made myself didn't quite measure up.) I also like their box rest.
Do you know if our area is one of those addressed by the threading jig redesign? (I suspect not. But,) If so, do you happen to know if the older threading jigs can be retrofitted? Mine is a couple of years old.
J.Jordan
Re: Best wood tools
Re: Best wood tools
>John I don't know the answers to your question other than if you are having problems vic will probably be able to take care of it. The new piece is a brass threaded rod instead of aluminum. He said he only had 2 that had problems. At least that's what I remember.
Re: Best wood tools
Re: Yes, it has a set screw,
Allen Neighbors
>that I put in it. I'll give that a try. Thanks, Mike.
Re: Best wood tools
Re: Best wood tools
eliot d
>I must be missing something. I have always used whatever tool rest comes with my lathe. Right now I have two, the Powermatic 3520A and the Jet Mini. So what's the big deal about special tool rests? I have never found the slightest problem with the standard ones. I believe the major causes of vibration are do to the geometry of the piece ( e.g too thin or too far from the spindle, or perhaps, to the type of wood (e.g. alternating hard and soft grain) or a dull tool, or cutting in the wrong direction -- these sorts of things. I would bet any vibration due to the tool rest is a second or third order effect. If you are really concerned with the vibration of the tool rest, choose a metal where the ratio of the bulk modulus of elasticity to density is low. Bulk modulus of elasticity is analogous to the spring constant of a spring.
Re: Best wood tools
Re: Best wood tools
JKJ in East TN
For one thing, additional tool rests both longer and shorter than the "standard" rest can be helpful.
Re: Best wood tools
Re: Best wood tools
eliot d
>I see your point about longer or shorter tool rests, but I don't understand the fuss about vibration being much of a problem coming from one.
