>Just wanted to bring to your attention and remind everybody of the tons of really great articles found in the WoodCentral Articles section. I have recently been thinking that investing in that Beal buffing shaft would be a real time saver for buffing smaller stuff like pens, bottle stoppers and mini hollow forms. You have all 3 wheels on a single shaft. I just now came across this article and thought to myself. Self? Aren't you glad you didn't spend $88 bucks on the one in the catalog! Cruise the articles section when you get a chance. There is more info there than you can imagine.
>Jen, I think you'll find that individual wheels, mounted on a separate motor or on your lathe, are more convenient and versatile, especially for larger items. ........Ron
>Hi Ron, I already have all three wheels that mount via a morse taper into the spindle on my head stock. Have used them for years. But I'm thinking it would be nice to have this setup to leave on the mini lathe. It just might be quicker for a runs of pens, or stoppers or anything small that doesn't require you to get inside like a bowl. Then when I need to buff a bowl, I can use the individual ones like I do now on the other lathe.
>Jen, it was my experience that the Beall 3-in-1, which is designed for use on the mini, has the wheels mounted too close together. I found it very difficult to buff anything without hitting an adjacent wheel. I finally took mine apart and modified the wheels to mount on my Don Pencil bowl buff mandrel.
I have today just finished my version of the 3 wheel setup. I used a 1 metre section of rod though, gives me over 9" between wheels. I did not grind off the threads but slotted lengths of plastic water pipe over the exposed rod. I am going to mount the whole thing on a wall later today, I shall post a photo of the setup soon.
>Keith, that's what I thought too. For sure you couldn't do bowls on it. If I make my own I can space them out farther. Even on the JET mini they would probably be too close. To have one that was already assembled and I could just pop into the big lathe with adequate spacing would be really nice.
>I made mine with all thread rod to be held in the chuck. I also bought buffing wheels with 3/4" holes so I didn't need to enlarge them. I haven't done it but I think it would be easy enough to make up individual wheels as well. The 3 wheel buff in my opinion now that I have one is it isn't good for anything but small items.
>I made this 3 wheel set up using the threaded rod, everything was great, made a holder out of ash for the end of the rod and the tailstock, the rod went inside the wood about 3". So, one day I'm happily buffing when in a split second (so quick I didn't know what had happened) the turning flew out of my hands and my right arm really stung and the lathe was going whack, whack whack. Just as quick I hit the lathe break, the tailstock hold had split, the threaded rod had whacked my arm, was really bent and was hitting the ways with each rotation. I don't like that 3-wheel set up anymore.
>I have an old motor and grinder wheel with wire brushes set up bolted to a table. My Dad made it in 1939 (date scrathed on top along with pertinent info; he was an electrician at NBC studios so his wiring is a tad different). That has nothing to do with my question.
I want to put a buffing wheel on one side so it hangs over the edge of the table. Nick Cook did this and it is the BEST thing since pockets. I have to push the spindle so it's 75% on one side with about 2" sticking out the table side. Got it done, looks great, motor doesn't work (and you would not believe how dirty, greasy I got taking it all apart!) The wiring is soldered to and into the motor and this wire is about 3/4" (?) diameter, there's no bending it. Is it a lost cause?
I prefer individual wheels (instead of the gang mounted three wheel setups), as there is more room to work larger pieces when buffing. Also, a three wheel setup allows for easy cross-contamination of the wheels when buffing. :-o This can cause numerous problems when buffing ultra-high gloss finishes or softer finishes like wax, if the residues from one wheel contaminates the wheel you're working with at the time . Good luck and best wishes in all of your woodturning endeavors!
>I would be leary of putting one end in the chuck for the same reason Ruth just stated. There was a guy killed in the metal shop that did some work for. He stuck a piece of rod through the headstock and left 3 feet hanging out the back side. All was going fine until it started to vibrate. Before anyone could move the rod bent 90 degrees and hit the guy and killed him. I wasn't there that day and we all knew you shouldn't do that sort of thing.
With the Beal many people are buffing at high speed. If that rod comes out of the tailstock and is fastened in the headstock it's going to be nasty. I think it would be much safer to rig up a drive center to drive the rod. Then if it came loose it would just fall off the lathe.
>Jen: For what it is worth, I have my buffs all on separate motors that have been salvaged from old discarded appliances. One is a motor off an old Mangle, several are from washing machines. These motors are cheap to find, and the only problem is finding bench space for all the motors. Cone adapters as well as threaded are available.
>I have two dedicated Baldor buffers, a 6 inch and an 8 inch. Both are slow speed and do a wonderful job. I used them for buffing flatwork boxes long before I had a lathe....
