Turning Alabaster is simple *3 Video
Ron in Drums PA
>If you can turn a bowl or a box you can do it.
BTW - No gouges, only scrapers
Video 1
Video 2
Video 3
Re: Turning Alabaster is simple *3 Video
john pickett
>Thanks. I have been thinking about doing alabaster and checking out sources of supply. I addedd this to my bookmarks.
I've purchased from these folks *LINK*
Ron in Drums PA
>Slow if you buy in small quantities, but top notch stuff.
Shipping is a killer.
Alabaster
Re: Warning
russ Fairfield
>If you are worried about breathing and collecting wood dust, you ain't seen nothing until you turn a rock.
Have you turned rock Russ?
Ron in Drums PA
Steven Antonucci
Shipping is worse than the stone!
steve antonucci
>I carve soapstone once in a while, and usually, the samll blocks can be had for almost nothing ($3 ea).
Shipping in priority mail box would cut the costs dramatically? Have you asked them?
Steve
P.S. Lot of stones can contains asbestos. you should always ask...
Re: Warning
>I asked Rude Osolnik what kind of lathe it took to turn alabaster. He said "someone elses".
Re: Warning
Mike Cunningham (Cape May NJ)
>I believe Angelo's into turning that stuff............
Bob Way, Canton, MI
>It's one of my favorite materials to turn. Yep, dust is bad and it can play havoc with the high speed steel scrapers, but results always seem worth it. And there are workarounds for the dust and tools. No catches, either.
Bob Way
Canton, MI.
Turning Alabaster
Ron in Drums PA
>Might even be less dangerous than some spalted wood.
Dale Cook
>I've been turning alabaster for about 3 or 4 years, along with wood. It's compressed gypsum and I've been working with that at my real job drywall for 35 years.I think it's like anything else,you take the precautions to protect yourself. Dust collector,mask,air cleaner,etc.It sure is pretty stuff.
My thoughts exactly Dale
Ron in Drums PA
>Stone dust is heavier and settles quicker than wood dust. It just doesn't float around like wood dust does.
Also, wood dust can be just as abrasive.
Re: My thoughts exactly Dale
Stuart Johnson
>I worked in a mine in Colorado for a while and one of biggest concerns was rock dust. Once it is in your lungs it is there forever. There is a term for it but I sure can't spell it let alone pronounce it.
Black Lung?
Ron in Drums PA
>My grandfather was a coal miner, and this is what got him.
Steven Antonucci
Silicosis?
steve antonucci
Rick in Colgate, Wi
>Dale,
Have you tried turning gypsum or is it too soft? I have a yard full of the stuff and have thought about putting a piece on the lathe.
In Case Someone Forgot
Ron in Drums PA
>Turning is a dangerous sport, We should all use and wear dust protection. No matter what we turn
Wood Toxicity 1
Wood Toxicity 2
Wood Toxicity 3
Stone Toxicity 1
"NOT SIGNIFICANT OR SLIGHT HAZARDS, VERY SMALL AMOUNTS FREE SILICA
alabaster, amber, bone ash, calcite, carborundum, diamond, dolomite, gypsum, hematite, jade, marble, putty (tin), travertine, whiting, wollastonite."
Stone Toxitcity 2
Stone Toxicity 3
Bottom Line: Be Safe
eliot d
>Does it dull your band saw blade?
