New Oneway - 1642 SD (?)
Barry Turner
>Has anyone seen the new Oneway lathe that is designed for use sitting down? This may be a great innovation for someone with a handicap, but otherwise it just looks a little too weird. What about all of those cuts that require "Body English", or the "Woodturner's Sway"? I would think they would be very hard to pull off from a sitting position. Without more information, I'm afraid I can't take this newest "Big White" offering very seriously.
Re: New Oneway - 1642 SD (?)
Carole Valentine
>Hi Barry,
The SD was designed for folks who can't stand for any length of time or are confined to a wheelchair. I think it is a great idea. As for Body English, you may be surprised at how well people can compensate when they don't have the use of their legs.
Allen Neighbors
>Barry, I've got a friend that always turns while sitting in a chair. If he uses the woodturner's sway, I don't know... but he really does turn some nice stuff.
I think this lathe's an offering for those that are required to turn sitting down, and it brings things down to the point that they can reach it better. I've tried turning while sitting (when I'm pooped out, and when I cut my knee and it hurt to stand) and I wished my lathe was leaning towards me a little.
I'd like to turn on one of these, just to try it out.
It possibly may not be around for long... but I'm betting it'll be around for years. There're a lot of handicapped folks that would like to turn.
Just my thoughts on it. :)
Barry Turner
>I've never tried to turn from a sitting position. I may have the same problem some day....who knows? It's amazing how people can adapt to various situations. I don't know if I could do it or not. (How about that blind golfer who got the "Hole-In-One" a couple of weeks ago?
When you think about the new lathe, the Oneway folks really had their "Thinking Caps" on. I hope it works out well for them........and all those folks who have a need for it.
Wally Dickerman in Arizona
>I examined the new 1640 at the Portland AAW show. Looks like a winner for those that need to sit while they turn.
Wally
tm
>As a turning wheelie I'm really excited about the SD 1642.
I've been using an adapted nova dvr xp and I'm quite content.
However, I've read everything I could find about the SD and most people who have seen one seem to agree that because of the
headstock / tailstock "swing" it is better suited for spindle turning
versus facework. I don't know...
I'd like to get next to one.
tm
tm
>As a seated turner my cuts dont incorporate body english with the feet apart stance and the sway /weight shift with elbows tucked in close to the body that most of us learned as beginners.
I do try to emulate the same type of motion and stability using my upper torso, elbows
and shoulders as props & braces.
I utilize the bench surface, the ways,
headstock and tailstock to lean on.
Isn't it a 1242SD???
Ralph
>Or is there some even newer lathe
its actually a 1236 nm
tm
It does say 1236 in their ad
>I think it's a great idea, not for everyone, but then neither is the Klein mini or the VB36. I do think the bed would get in the way for my style of turning bowls but then if I was forced to sit in a chair I would probably adapt that style as well.
I love seeing all the new stuff coming out, tilting lathes, oval turning chuck, etc. These things are possible because the turning community is growing in size. You simply wouldn't spend the R@D on stuff that has a small market place. I think we owe the AAW for that. When I started turning lathes over 12" were rare, homemade or really expensive. Mini lathes didn't exist (not counting the sherline metal lathe which could be converted to wood). Bonnie Klein saw a market for mini lathes and they took off. We've seen a huge growth in lathes and tools. Chucks were not heard of or were adapted metal lathe devices. Now you can buy just about every size you need. Heck even bowl gouges were new. Rude Osolnik ground a rectangular piece of HSS into a bowl gouge. The outside was still rectangular but the bevel and inside looked the same.
Well I was told that..>>
RonZ
>>> since I'm so short I can use it standing up when its set for sitting down for everone else.
Keith Tompkins
Re: It does say 1236 in their ad
keith tompkins
>You are right-on as usual, John. Those who constantly belittle the AAW do not see the bigger picture. Most of the innovation that is occuring is a direct result of the AAW bringing us all together.
I saw the sit-down lathe in Portland...looks pretty good! It's easy to swing the whole thing from sit-down to standing mode.
Dick Hines
Dick Hines
>I don't need a sit down lathe but I have given some thought to useing a bar stool while sanding.
Dick Hines
Dick Hines
>Don't even think about it. I don't drink.
