natural edge bowls
natural edge bowls
natural edge bowls
John Purdue
>I have never turned a bowl on a big scale, all I have is a jet VS mini lathe. I make turkey calls and it serves me well for that.
But I would like to turn a small natural edge bowl and would like to know how you guys keep the bark on and how do you finish the bark?
Sincerely,
John Purdue
Re: natural edge bowls
Re: John- how much time do you have?...
Jamie Donaldson
>... That is a loaded question, and the short answer would be "work carefully and CA glue!" I'll let someone who can type faster fill in the details for you!
John Purdue
>I have all the time in the world to do this. I just want to try something different. I love doing my turkey calls but need to do something a little different.
Carole Valentine
>Best thing to do is find someone near you to demonstrate. It's too much to type. It can be scary at first until you get used to the sensation of going very rapidly from cutting wood to cutting air! There is a lot of "feel" involved. A few things that come to mind: Turn the rim to thickness first, because once you hollow the rest of the bowl, you can't go back to the rim - it will flex too much without the support. Cut into the rim towards the base - if you cut towards the rim you will knock the bark off. Use wood that was harvested in the winter when the sap wasn't running - the bark is tighter. I use the same oil on the rim as I use everywhere else. Only time I use CA is if absolutely necessary if a piece of bark has become unstable. I don't like to use it at all if it can be helped. Do a search on Google for "Turning a natural edge bowl" and you probably will find some good info. I think Bill Grumbine may have a section on his web site.
Re: John- I posted your info with ....
Jamie Donaldson
>... the natural edge pecan bowl just now- hope it helps get you started.
John Purdue
>Thanks for the information
