Veritas - Innovation in Tools
What I learned from a good demo *LINK*
Gordon Seto
>Doug Thompson did a full size cowboy hat demo for our Club last month.
I posted here: http://www.woodcentral.com/cgi-bin/turning.pl?frames;read=158277
That was the fourth such demo I have seen. The first three never inspired me. They were good; I enjoyed watching them as entertainment. It was like a beginner watching Richard Raffan DVD; you hope you can do that someday but intimidated.
Doug talked to us in our level. He said his techniques can be applied to thin wall turning. It inspired my wife to take the core-out from the hat demo home; she demanded me to try a mini hat. I said I don�t have the light fixture, so I turned this thin wall bowl.
It is 6�� diameter by 3�� high, Danish oil finish and buffed. Wood was from Doug�s hat demo, which he salvaged from the city dump. He said it was some sort of maple. It has 1/16� wall thickness and weights 2.1 oz.
BTW, Doug himself is not using the grind that he posted in his web site. He uses a free hand grind. I didn�t want to mess up my Thompson bowl gouge. So I used my Sorby and adapted his free hand grind. Sorry, Doug
Gordon
Tool Sharpening
Re: What I learned from a good demo *LINK*
Doug Thompson near Cleveland
>Very nice Gordon, I need to learn how you finish the wood. BTW Gordon had this at the club meeting this past Saturday... it's light as a feather.
Good Job!
George Van
>I like the curve on this Gordon, it has a nice flow, which at time is difficult to accomplish. Your finish looks flawless and I can imagine it feels like a feather! Was the grind you used similar to the Batty grind?
Gordon Seto
>George,
Thanks for your comments.
That is my interpretation of Batty grind (I hope I got it) with the heel rounded off. I believe from what I saw in Doug's demo, his grind is similar except the nose angle is around 45� instead of 40�. Only a short bevel is needed to control the direction of cut. The heel from the hollow grind would put too much pressure on the thin wall.
BTW, all comments are welcomed. I couldn't find any editing feature in the WC message system.
Gordon
IMO a large bevel is not needed
>The Batty grind on a U shape tool is perfect or the Michelsen grind on a V shape. Gordon, I like the grind you have on the tool.
I might be wrong but it doesn't sense to me why on a standard grind the bevel has to be so long. Rub the bevel, which is the heal of the tool and your cutting edge is a 1/4 inch away on a 1/2 tool.
Why not remove most of the bevel so the two points of contact are close to each other.
Any thoughts or comments.
George Van
>It looks like you got a nice uniform edge Gordon, good technique!
Re: IMO a large bevel is not needed
George Van
>I may try this on the U shaped tool I got from you Doug. What is the Michelsen grind, I have not heard of that one?
>George, Johannes Michelsen www.woodhat.com will take a V shape tool and remove most of the bevel. If I could find a picture of his grind I'll post late tonight.
He will grind a 1 inch shallow bowl gouge like that too. With that grind he can remove wood faster than anyone I've ever seen... huge shavings. OR with the same tool angle hair OR a beautiful scraping cut OR a beautiful finish cut inside of a bowl. I wish he would give a bowl turning class so everyone can learn how it's done.
Re: The wider bevel is more .....
Jamie Donaldson
>.....supportive and user friendly for inexperienced turners. There is a finer line from cut to catch without skilled tool control that comes with much practice.
