>And after I did get the face plate off, the bearing was making noise and a neighbor who had a machine shop came over and his diagnosis was that I melted the lubricant on the front bearing? I also had snapped the indexing pin.
Well, 2 local (in PA) dealers don't have parts, called General, they said to just pull off the bearing, go to a local bearing place, it'd be cheaper and faster. At least General admits it's service isn't the best! Then I called my machine shop, Stef said to get CRC white lithium grease, take off the front plate around the spindle, spray it into the crevice". It's a sealed bearing not an enclosed so he said the lithium would work it's way to the bearing.
It's amazing, the General is back to new, can't hear a sound from the bearing.
>Not really, remember I heated up the spindle to get the face plate loose and then I posted that the General was making funny noises. I melted the lubricant on the head bearing and it was rubbing. It was so loud when I turned above 2800 rpm that I couldn't hear my audio book and that's when I knew I needed to fix it. Nothing broke.
Your post creates a vivid image, and also raises several questions that you or someone else might be able to answer.
The concept of a broken general brings to mind a great general, defeated by an exhausting war, formally surrendering his sword with quiet dignity!
The questions:
What's the difference between sealed and enclosed bearings, and how do you know which you have? Does anyone know what the Woodfast Lathes have?
How do you melt a lubricant? Is it literally a case of a solid becoming a liquid?
If you do have sealed bearings, does spraying them with lithium white grease help to protect them from wear? I was under the impression that it doesn't, but what you posted makes me question my belief.
>Hi Ruth, I hope you just got that backwards and you really heated the faceplate. Otherwise it would expand the spindle and make it even harder to remove the faceplate. If the spray worked so well then I would get some lithium grease and pack it around the bearing. Mike
>Hope you have no more problems with the bearing for a long time, but I can't imagine a shielded bearing getting adequately lubed in this way. Keep us posted.
>We would repack the front wheel bearings of our cars and trucks by holding a palm full of wheel bearing grease in one hand and cutting the edge of the bearing into the grease with the otherhand. It was time consuming, required patience and skill but was effective. Wheel bearings are open, they don't have shields. The seals are part of the wheel hub. So if you carefully remove the shield on the bear ing of the General apply some grease out of a pressurised can, then replace the shield, You should be OK. ET
>There was nothing broken, the bearing was just rubbing, crying for grease. Sort of like my bandsaw is screaming for new brushes.
I was told if the bearing has rubber around it, it's encased and you can't get grease to it. If it's all metal, there is a teeny space between the spindle and the metal around the bearing, it's called a sealed bearing and the spray lithium will work it's way inside. I sprayed it lightly, turned the hand wheel a few times, waited a few minutes, sprayed again, waited, turned the wheel, then did it all again. About 20 minutes later I turned the lathe on, going through all the speeds and he's humming like a good General should.
I called Industrial Supplies in Albany (or near there), who I bought the lathe from at the symposium up there. It's not a store like Woodcraft but exactly what the name implies. I told him I also snapped the index pin and he said he'd just send me one free.
("How do you melt a lubricant? Is it literally a case of a solid becoming a liquid?")
When I heated up the spindle, it melted the lubricant, that's what I was told and all I can do is repeat it because I have no idea!
("If you do have sealed bearings, does spraying them with lithium white grease help to protect them from wear? I was under the impression that it doesn't, but what you posted makes me question my belief.")
Dinyar, I don't think it helps them from wear (which sealed bearings should Never wear anyway), I just had to replace the lubricant before I ruined the bearing all together. The stuck face plate episode was a few months ago and I've been using the General occasionally all along.
>I don't think that General was saying their service isn't the best. They were saying it's cheaper and faster to obtain an off-the-shelf bearing locally. I used to make the same recommendation as chief technician for a Canadian printing equipment importer.
I had a somewhat similar problem with a 35yr old RAS bearing. It was shielded and bone-dry from all the dust blowing across it. Took bearing grease, souped it down with some naptha, and pressed it past the shield. That was a year ago June (06) and no problems as yet.
>Ruth, quite possibly the seal itself needed lubrication. I rides against the spindle, keeping grease in and dirt out. A spray lube would work, in that case. If no grease ran out past the seals, then the grease may have melted from heat, but it's still in the bearing, and should have resolidified when it cooled.
>Dinyar, I'm sure a sealed bearing is in your woodfast lathe. If you ever need to change them take the old bearing to the local bearing distributor and have them match it up with what came out of the lathe. Chances are you will never need to replace them.
The rubber seal keeps the dirt out and the grease in. When the bearing is heated the grease turns to a liquid and drains out.
>Bearings are surprisingly cheap. I had to find two bearings for my old bandsaw, which was a really odd size. It cost $15 for the pair, and properly maintained, should last at least 10 years. Assuming that the General has standard size bearings, and I can;t think of a reason why it wouldn't, my bet is that a pair of bearings would be even cheaper.
