Toast?
Toast?
Toast?
Carole Valentine
>My Delta cordless drill started smoking tonight. It still runs, but I am afraid to use it. It's no huge loss since it came with something I bought and I just keep a socket on it for driving faceplate screws. I'm just wondering if there is something I can do to save it? I keep it blown out so it wasn't dust that was smoking. I have noticed a strange smell coming from it for the past several days. Toss it?
Re: Toast?
Re: Toast?
Kevin Gerstenecker
>Unfortunately Carole, once you let the smoke out of them, the are not long for the world! I would keep using it until it gives up the ghost. Driving face plate screws takes quite a bit of torque, and that can be hard on cordless drill/drivers.
Re: Toast?
Dick Hines
Re: Toast?
Dick Hines
>Carole, as we say when we get ready to turn up a new telephone swt. "let's give it the smoke test". I think you gave it the smoke test. Smells like toast.
Re: Toast?
Re: And you can buy a new one.....
Jamie Donaldson
>... for a lot less than attempting a repair these days.
Re: Toast?
Aha, you're supposed to clean drills??
Ruth Niles
>I've never blown my drills out, I have 2 elec. and 2 cordless. One of the electric drills is so old it has one speed no matter how light or heavy you are on the trigger and it only goes forward, I've used it darn near every day for 16 yrs. and never cleaned it. It works like a charm. oh great, tomorrow morning it will die!
Carole, I agree, use it until it's totally gone.
Re: Toast?
Re: Aha, you're supposed to clean drills??
Carole Valentine
>I don't know...just seemed like a good idea to blow the dust out of it now and then. Maybe that's what killed it!
Re: Toast?
Re: Toast?
Bruce Wiseman
>It might just be the brushes. on the motor end of the drill look for two screw caps (usually about the size of your little finger tip) gently remove these and there will be a spring inside with a small piece of carbon rod. You can get replacement at a good hardware of electrical store for a couple of bucks.
Bruce
Re: Toast?
Re: Toast?
JKJ in East TN
>If you take it apart, you may be able to tell where the problem is by smell. If the windings smell burned, throw the thing away (or if you are like me, save it in the junk pike in case you need to salvage some piece some day.) Note, overheated motor windings are often accompanied by reduced power. Bad brushes are sometimes noisy and make sparks.
Re: Toast?
Re: Toast?
Carole Valentine
>The thing has been making sparks ever since I got it. It does not have exterior access to the brushes so I will have to take it apart to look. Nothing to lose I guess. Thanks.
Re: Toast?
Re: Toast?
C.W.Stivison
>If you toss it save the chuck. Very handy for lots of things
CW
Re: Toast?
Yes please...
Leppikallio
>...with some orange marmalade and big cup of blacker than black coffee.
Seriously I would toss that thing. I just hate to have any uncontrolled heat sources in my shop and battery drill may be one of those once it has began to smell....
I too have some old chucks from old drills and battery drills, among other important things, but I don't think that there is opportunity to use them lurking around the corner. I have been training myself on a daily basis about a month now. Soon I will be ready to throw lots of that stuff away. Problem is that this stuff has to be tossed at night and it also has to be carried so far away from home that it can't find its way back home. Sometimes I have tossed some stuff away and it has came back...!
Re: Toast?
Re: Toast?
keith zimmerman, Normal, IL
>My Delta cordless did that after just 4 months. I took it to a service center under warranty and they said they would have it back to me in a couple of weeks. I received a check from them instead, reimbursing me for the value of the drill. I used the check to buy myself a new Riobi cordless drill. Seems the Delta wasn't worth repairing or even replacing.
keith
Re: Toast?
Re: Toast?
Carole Valentine
>That's why they gave them away with the purchase of a drill press or some other bigger piece of equipment. There is no free lunch.
