THE WOODRAT IS BACK!
Turning Brass 360
Turning Brass 360
Turning Brass 360
dwr
>A quick update from the previous posts regarding the grind on my gouges. Thanks to Wally, Jamie and the rest, I was able to regrind the small "hump" from the wings and it worked great.
Now I have some other questions.
I cut the Ash handles off my Thompson tools because they were too light for my taste. I am making some Aluminum handles to fill with shot. I want to do all the work on my wood lathes and know I can turn the Aluminum, However, I also want to turn some "Brass 360" and could not find anything in the archives. Brass is supposed to be soft and I think I can take it slow and have a go at it.
For you metalworkers: Is the Brass 360 alloy soft enough for turning on my spindle lathe? (I have several HSS tool bits I can rig up as well.) What RPM would you recommend I set my VFD for?
Thanks... looking forward to posting the new handles... if all goes well...;)
Dave
Re: Turning Brass 360
Brian Hahn in SW Wisconsin
>I'm not familiar with Brass 360, but I have turned both brass and mild steel on my wood lathes. I used standard HSS scrapers and ran in the 300 rpm range.
>I'm not familiar with Brass 360 either. Just try to turn it. If it's too hard heat it up to red hot and then quench in water. That will anneal it so you can turn it. I use spindle gouges mostly to turn brass but any HSS tool will work.
Steven Antonucci
You can turn brass
steve antonucci
>But it's a big mess, with a million little metal shavings everywhere. Don't use a bare hand to brush off the lathe ways, or you'll get 10,000 little brass splinters in your hand (DAMHIKT)
I laid a plastic bag over the ways to help contain the brass shavings. Worked somewhat, but you'll still have metal everywhere for a long time.
Steve
Thanks guys...
dwr
>... will try Brass or Mild Steel.
Dave
Steve...
dwr
>... have you tried mild steel using HSS bits?
Dave
Steven Antonucci
just drilling holes
steve antonucci
>I actually turned copper and brass with a Sorby gouge (HSS) to dimension, but I've only tried drilling steel once along the length on the lathe. Results weren't much better than hand drilling in a vise, but 3 times as messy, so I don't chuck steel any more.
Steve
