Neat new tool *LINK*
Ron in Drums PA
>Can't wait until I get home to try it out
Tilt Box
Ron in Drums PA
Tilt Box
Re: Neat new tool
Andy DiPietro
>Hi Ron,
Looks like a good new tool. Good for the visually impaired, like myself. I thought you told me that your table saw was mostly a woodturning display table like mine :>)))).
Andy D.
Re: Neat new tool
James McClure
>A friend of mine just got one of these and was very happy with it. He said it was surprisingly accurate. Just zero it out against the table and you're good to go.
Re: Neat new tool
Ron in Drums PA
>All my segmented turnings use staves, which are compound miters.
I find it the easiest to use my compound miter saw for staves.
I plan on using the tilt box to check the miter when I tip the blade.
Now, If I could find a digital protractor to measure the angle when I swing the blade I would be set.
Re: Neat new tool
George Van
>Ron, I want to get one to use on the rest of my grinder. I thought as long as I know what degree reading it was giving and recorded that reading, (doesn�t have to be an accurate absolute reading because the grinder stand is stationary) I could reset the rest to that angle reading the next time I wanted to sharpen that tool. Could you let me know if is accurate enough to do this and that is a possibility once you try yours?
Re: Neat new tool *LINK*
Andy DiPietro
>I wonder if it will work like a protractor in the other plane. You may want to try zeroing the box off the backstop and see if it will measure the cross cut swing angle too.
Or you could buy a Bosch digital protector and set the swing angle with it.
Just what I needed!
Ron in Drums PA
>Thanks!
Re: Neat new tool
Stuart Johnson
>I have the Wixey which is the same thing and it works great. Just zero it out on the saw table and you are good to go. I've used it on my drill press, jointer and disc sander as well.
Re: Neat new tool
Bill Blasic
>I too have the Wixey which I picked up at Rocklers last Saturday.
Re: Neat new tool
RonZ
>I have had the Wixey [same thing] for a while and besides its other uses, I use it to set my sharpening table.
Re: Neat new tool
George Van
>Ron, do you use it for an accurate angle or just a reference angle for re[eatability on the sharpening rest. I would think a bevel angle would be difficult to read off the rest.
Re: Neat new tool
RonZ
>I use the Sorby and Tru-grind sharpening 'tables'. I use this for everything except long ground gouges. I zero it out and adjust the 'table' for 45deg for example. Then I do my bowl gouges and roughing gouges.
Thanks Ron!
George Van
Re: Neat new tool
Steve Worcester
>I have a Wixey also, but I don't think it will read or go back to absolute zero, which is a pretty neat feature. Might have to sell the Wixey
