Spalted Y. Birch NE
Spalted Y. Birch NE
Spalted Y. Birch NE
George Van
>I just finished this spalted Yellow Birch bowl. This was a good exercise for me in light, sharp tool control, something I needed. The bark was loose and impossible to retain so I used a felt tip to blacken the rim. It has a round bottomed, 1/16� walls, and is 9.75�x8.75�x3�. I sealed with Deft and finished with Russ� mix. I still have problems lighting the base, I will try to attend the WC chat tonight to learn more. Comments and suggestions are appreciated.
Re: Spalted Y. Birch NE
Very nice work!
Ruth Niles
Jennifer@Indy.USA
>George, this is lovely. I really like the look of the rim minus the bark and then blackened. A really beautiful piece!
Jen :)
Steven Antonucci
Did you use a steady rest?
steve antonucci
>I can hear that singing all the way in NJ! Great job on the bowl- love the round bottom.
Steven
Re: Very nice work!
George Van
>Thanks Ruth, I appreciate your opinion.
George Van
>Thanks Jennifer, I wasn't to sure that this would look too artificial.
Re: Did you use a steady rest?
George Van
>Thanks Steve, I did use the Oneway bowl steady and a sharp 1/4" gouge with the bevel relieved on the back.
Andy DiPietro
Andy DiPietro
>Hi George,
Nice looking bowl. I would be nice to see a picture showing the spalting on the inside of the bowl. Does spalted birch turn easier or harder then maple?
Andy D.
George Van
>Hi Andy, hope this photo helps. Yellow birch is softer than the hard maple when both are compared, spalted or otherwise. Tear out is harder to control in the Yellow Birch but not as bad as the white birch I have turned. It is about the same hardness as oak in my experience.
Phil Powell
>George,
This is an excellent bowl! Very sensitive shape and finish. I think we
could make a potter out of you. Way to go.
Phil
Cyril Griesbach
>You've done it once again, George. I just love what you're doing with all that spalted Yellow Birch.
Re: An excellent bowl form George, and ...
Jamie Donaldson
>... I have an observation about your lighting set-up. The light source is coming from the L somewhat behind the bowl, creating a shadow area in the R front quarter. If you will move the L side light forward the shadow will be placed more toward the back, and there will be more detail in the areas that are now not illuminated. Another option would be a smaller light on the side opposite the present primary source, but adding more light sources also creates more shadows. Backlight just doesn't work well when we are viewing from the front.
George Van
>Thanks Phil, a potter? Do they have spalted clay?;-)
George Van
>Thanks Cyril, it is a good old WI tree. As I said before, stop in if you are up here!
George Van
>Thanks Jamie, I will give that a try and be more careful on shadow placement. If I get this mantel finished I will join the chat tonight.
WayneLeach - NW Ont
>George,
Nice job on this NE bowl. I sure like the black edge which sets it off. The shape is very interesting.
Wayne
George Van
>Thanks Wayne, do they have yellow birch up there?
