OK, Lacquer Dudes. What'd I Do Bad?
>Finished a smallish footed bowl in Box Elder, and decided to use semi-gloss Deft lacquer.
Followed the label and applied 6 coates at about 1 hour intervals in 2 sessions, 2 days apart. Like the finish, however . . .
If I leave the piece on a smooth surface (glass etc.) the piece sticks to the surface after about two days. Obviously there is still come outgassing of thinner occurring, but there must be something else going on here.
What'd I do? and
When will it stop?
mm
Re: OK, Lacquer Dudes. What'd I Do Bad?
Dick Coers
>It's been my understanding that Deft is formulated as a brushing lacquer. For that formulation they use a very "slow" solvent so that the material will flow out and make a smooth finish.
The drying of lacquer is very sensitive to weather conditions (heat and humidity) and thickness of each coat. If the humidity was high and you put on thick coats, you probably put the coats on too quickly.
Deft does have some quirks. A friend of mine did a fantastic walnut desk with a perfect finish. Weeks latter he found out that the vinyl desk saver he had used to protect the finish, had actually melted into the desk top and ruined it. About that same time his daughter was very sad to find that the foot of her favorite doll had melted into the finish of a doll cradle he had made. Guess what finish he didn't use again!
In time all the solvent will outgas and it will be full hard. Just keep moving it around and maybe put a tooth pick or something under one side of the vessel so air can get to that finish.
Re: Deft
>This is in a spray can. They sell several flavors from full gloss to matte. Guess I'll just have to wait . . . . . . . . . . . .
mm
Allen Neighbors
>I second the thought that you may have sprayed brushing lacquer, applying too many heavy coats too fast. It will cure, eventually.
My suggestion is to take a small board, drill four 1/8" holes in it to form a square, deep enough to stand up some #6 finish nails, and the square small enough to fit the bottom of the piece. Sharpen the points on four #6 finish nails to a needle point, and insert them into the holes in the board - point up.
You now have a stand to hold the piece up so air will circulate well while it cures. If you're careful, the sharpened points will not leave a spot big enough to even notice. If you want, some 0000 steel wool and wool-wax will make them go away.
I used this method for years to cure my boxes when I was making about 200 or so bandsaw boxes a year.
Just my thoughts. Hope you get it figured out.
I thin it out and.......
Jake Niedling
>I use Deft frequently and mix it in a jar 50/50 with Lacquer thinner. I then wipe on with a paper towel and usually will put on two coats per day or once every evening. I lightly steel wool the piece between coats. Depending on the wood, I will put 4 to 6 coats. This way the finish is thinner and does not have that a heavy build-up look on the wood. Finish it by buffing on the Beal system. Never had a sticky finish. I am in Tennessee and do this in my unheated and non-airconditioned garage year around.
Re: Hurry Up & Wait
>So I guess I'll just put it on the saide for a few months and wait. So much for "quick finishes." |;-}}
Re: I thin it out and.......
Donna Banfield
>I, too, have had my share of problems with Deft Laquer on bowls and other turnings. But, I found that cutting it 50/50 with lacquer thinner has done the trick.
I use it now on off-center jewelry that I turn. I was looking for a way to seal the pieces, and spraying a finish didn't work beause it was nearly impossible to get the finish into the small crevasses in the off-center work. I tried dipping them in uncut laqcuer, but the build-up was 'globby' and unsatisfactory. Cutting it with thinner works quite well, and helps to reduce the 'globbing' that I got using it full strength.
I'm doing this un New Hampshire, year around. Wish I could say that I had AC in my shop :^( but I do have heat in the winter from a pellet stove.
Re: Deft
Darryl Hansen
>When I use Deft I srpay it on using a cheepy sprayer called "The Critter". Let it stand a day between coats and things work out well. After the final coat I wait until the finish "feels" good and then buff.Seems to work out the kniks that way.
Mike Nelson
>Mark, I use airless sprayed lacquer as a finish in my cabinet shop and though it is great because of the fast dry time, I always warn my customers to be gentle for the couple weeks it takes to fully cure and harden. For my turnings I have changed from gloss to semi-gloss and now only satin Deft spray it drys faster and you can buff or rub it out to any sheen. If it is a dry day, I add coats every 30 minutes with no problem. Mike
Mark Kauder, Phenix City, AL
>Folks,
The long and the short of it is, that Deft is really crappy lacquer for anything other than thin applications. I don't care if we are talking the spray can stuff or if you brush it on.
Reasons: 1) In either version, you get a very low solids content. The solids are what is left (the actual Nitro-Celulose)when the solvents evaporate. So if you want to build a finish, it will take 3-4 times more Deft than it would other higher solids lacquers. That means you will actually save more buying a lacquer that may cost 50% more. (spray cans are always a bad deal unless you only need to do one little project with it, because they are even lower in solids, so that it will spray with the low pressure provided by a can spray)
2) Because Deft is a brushing lacquer, it has retarders to allow it to dry slower so the brush strokes will flow out of it. As a result, the entire hardening process is slowed. Now, all lacquer will out-gas (to some extent) for up to two years, but the retarders in Deft are really slow. There are retarders that will slow things enough that you do not get Blushing (in humid conditions) or Orange Peel (in Hot/Dry conditions), but most of the higher quality retarders and lacquers will then harden quickly after the initial slowing of the retarder.
Deft is really slow for a really long time. You can apply Deft to a nice smooth finish, and it will seem hard, but months later, you will see that it has continued to shrink, and you will see grain showing through, etc.
Do I use Deft? Yes, I use it when I want an oil-like finish, and just thin it down, wipe it on, and then wipe it off. Or for as a sealer on MDF, etc.
But if you want a better lacquer for wood turnings, I would suggest something like Behlen's Stringed Instrument Lacquer. It has a high solids content, gets hard enough to protect from normal handling dangers, but is flexible enough to not crack with wood movement.
Mark
robert davis
>that is the way i do it..never a problem in 10 years
Russ Fairfield
>The solvents will not be fully evaporated and the lacquer will not have reached its maximum hardness untilo there is no longer an odor. That will be somewhere between 2 weeks and 2 months for most lacquer finishes, depending on the thickness of the film that the solvents have to evaporate through. A very thick lacquer film can take up to a year
Re: The only problem.....
Russ Fairfield
>A brushing lacquer uses thinners that evaporate at a slower rate so it stays liquid longer to allow for leveling of the brush marks. The only problem with spraying a brushing lacquer is that there is a greater possibility of runs and curtains forming because of the slower drying rate on the surface after it has been thinned for spraying..
The differences in evaporation rate are so small that I doubt anyone could notice the difference after the initial surface film has been formed to where the finish will no longer run.
Mike Jones
>As mentioned above, humidity and laquers don't get along well. If you must work with lacquers (e.g. deft) in high relative humidity conditions, ask your paint dealer for a "fast" thinner. (Most off-the-shelf lacquer thinners are medium fast), then simply add a little time to the instructions on the label.
eliot d
>You used to make 200 band saw boxes a year? That's a lot of boxes. Did you sell them to a craft shop or something? I recently (at the Yankee Symposium) saw a demonstration of several band saw boxes that have turned lids (Beth Ireland. And she has a DVD of it, too.) Have you thought about such boxes that involve turning?
>So I guess the deal is to take the spray can stuff back to the paint store for the next poor sucker to pick up.
I do have a small touchup gun I can use, but the cans were convenient.
Thanks to all.
mm
Russ Fairfield
>There is nothing wrong with using the spray cans of lacquer other than you are paying a high price for a whole lot of thinner and just a little but of lacquer. They are still a lot cheaper than buying an air compressor and a spray gun if you don't plan on spraying very much lacquer.
Re: Sometimes over 200 a year.
Allen Neighbors
>It just depended on how much I got to work in my shop, and how "into" it I was that day... sometimes I could cut out and glue together 5 or 6 in a day (two or three drawers). I sold them from my home (word gets around and people would come for unique birthday gifts, etc), and they sold well in craft shows.
I've turned a few lidded boxes, but getting stable, cured wood isn't easy here. I don't like to make the tiny ones, even though they've sold well.
Cans
>It was more convenience than anything else. Have the compressor and the guns, but dragging everything out, setting up, spraying, then cleaning the gun and dealing with the used thinner and ventilation of the windowless basement shop was too much hassel just to spray-finish one 7" bowl. Hand-applied oil and shellac finishes, while they take longer, are better suited for my facility.
Thanks for the thoughts.
mm
Re: Hey, Mark. Don't clean your gun...
Allen Neighbors
>unless you use it for spraying other mediums.
I've been using the same spray gun, dedicated for lacquer only, for about 15 years... or 12, at least... and I haven't cleaned it more than 3 or 4 times. About every two or three weeks, depending on usage, I take the fan nozzle off and drop it in a little jar of lacquer thinner. My gun hangs on a hook with lacquer in it, at all times.
Lacquer melts lacquer. When I get ready to spray something, I take it down off the hook, pull out the wire I keep in the breathing hole, connect the air line, pull the trigger and at the same time, rub my finger across the nozzle a couple of times. Then I spray the piece, and re-plug the breather hole, disconnect the airline, and re-hang the gun.
An old furniture repairman from Oklahoma taught me this about 35 years ago. Sure saves a lot of time.
NCD, Al
>Most all my spray finishing is on flatwork using waterbornes. Guns need to be cleaned. Thanks for the tip, however.
mm
