MT # 2
MT # 2
MT # 2
Bill Crommett
>I need to know the formula for turning a Morse Taper # 2 for jam chucks. While we are on the subject, give me a rundown on the technique.
Re: MT # 2
Re: MT # 2
Wally Dickerman in Arizona
>Bill, I don't have a formula, but I've turned wooden MT's by laying an existing MT such as a live center, on a board. Then, take 2 small pieces of wood with a little glue on the bottom, and snug them up against each side of the MT. You now have a way of testing your wood MT.
Wally
Re: MT # 2
Re: MT # 2
>Wally has a good Idea. Make yourself a "feeler gauge" or caliper.
I have an "E" I bought at a demo. On slot in the E is the small end of the taper and the other is the large end. The spine of the E is the length. Looked like a really neat Idea and I guess it was, but I don't use it anymore. I just copy one that actually fits my lathe. I could take the measurements of the E if you are interested but you could just measure one of your tapers and create one yourself.
I often turn small things like finials by taking the stick and grinding a quick taper on it on my belt sander that is in a cradle on the work bench. Then I just drive it into the headstock. With a mallet. Then I bring the tailstock and force the piece to center up and run fairly true. I make it round with the tailstock in place and then push the tailstock back out of the way.
Re: MT # 2
Re: MT # 2
Dick Coers
>I did a quick google and found this cool chart for all Morse tapers.
http://www.geocities.com/Axiom43/morsetapers.html
Seems it tapers .05" per foot
Re: MT # 2
Re: MT # 2
Bill Crommett
>Wally:
Sounds good. Also sound simple enough for me to understand and work out. Thanks
Re: MT # 2
Re: MT # 2
JKJ in East TN
>I make short morse tapers (about 5/8" or so) to jam long, thin spindles for turning. I made a gauge from a piece of sheet brass with the proper diameters cut into each end of this short taper. After rounding the end of the square blank (between centers), I hold the small end of the gauge against the work while reducing the diameter on the very end of the blank with a narrow parting tool, then move over about 5/8" and cut down to the larger diameter. (I made a 5/8" mark on the gauge to get the distance right.) I then turn the taper between the two diameters with the same tool. I find 1/2" or so is plenty to hold the end of the blank securely without wasting too much wood.
I generally make up a bunch of these at once and test as I go in a second lathe to save removing the drive center for each test.
Before I made the gauge I used a method that was faster but not always as accurate: I set some cheap calipers to the larger diameter (in essence a gauge similar to the one above) and turned a short cylinder, then turned down a taper by eye. After a few dozen of these it's easy to get it real close.
BTW, since the taper holds well when gripped at only the small and large diameters, and since any oversize sloppiness in between can greatly decrease the grip, I generally remove a shallow band in the center of my 5/8" length after cutting the taper.
Re: MT # 2
Re: MT # 2
>Bill I do both what wally says and some measuring. I measure a steel morse taper. I measure at 2 places 1 inch apart. Then I use the parting tool to cut the 2 depths at 1 inch apart. I then connect these two. This gives me the taper. I check it on my jig which I made by glueing 2 small boards onto another board so they just touch a steel morse taper. You could also measure the steel taper 2 inches apart if you need a longer taper.
This is similar to the "E" jig that Mark Stleger uses. The distance between the long arms of the E are maked and then the gaps between the top and bottom E arms are the right size for the large and small size of the taper. Much quicker than my method but I've never taken the time to make my "E"
Re: MT # 2
Re: MT # 2
Pete in Holland, MI
>Once the angles are determined, cut a piece of plexiglas or sheet metal to create a "V" that matches the angle on both sides of the MT. Sliding this on to your turned stub will replicate a center line cross section of the MT female socket, verifying both angles are right, and that the surfaces are cut straight.
