One more question
One more question
One more question
Jim Rutten
>My "shop" is about 1/2 of 1/3 of the basement (the other 2/3 is finished). I was told it wasn't a good idea to use spray on laquer there because of the furnace. Are there any other finishes that are bad to use in a basement shop because of a) fire or b) lack of circulation? Thanks for your responses.
Re: One more question
JKJ in East TN
>Jim,
I personally would avoid using any finish in a closed space without good ventilation. Look on the labels - most finishes are flammable but I know none that are good for lungs. When I build my new shop I'm going to include a vented spray booth. If you can punch a hole to the outside somewhere, you might make a small vented spray area suitable for turnings. A booth made from something as simple as a cardboard box or thin plywood that can be knocked down when not needed might work fine. An explosion-proof exhaust fan is best, but I've read that an induction motor (without brushes) is also safe if it doesn't get too hot and if it's used with a safe switch.
BTW, there is a cabinet shop down the hill from me run by an 85 year-old man. He does all of his finish work outside. Delivery times with him must also factor in the weather!
