>I need to drill some equally spaced holes around the rim of a bowl. My lathe has the indexing but I'm looking for anybody with pictures of a jig built for their lathe. The holes will end up being used for weaving a rim on the bowl. This is a collaboration with my mom for a silent auction piece at a craft show. She's an expert basketweaver.
>The Oneway jig is terrific. Using the jig will make you feel like a machinist.
If you want evenly spaced holes use your indexing and mark the hole locations with a pencil. Then drill the holes by hand. Sharp drill bits make a big difference. A center punch can be used to help with the process. Brad point or bullet point bits help.
>I made a little support for a Dremel Tool. It just as a strip of wood under the base that slides in the slot in the ways. I think I just held the Dremel in the Cradle but you could fasten it in the a nylon snap tie or a hose clamp. The problem is that it was limited to 1/8" bits, unless somebody makes other bits with 1/8" shanks. It was pretty crude but it worked. Another problem was that my lathes indexing head had a limited number of "stops". I overcame this by offsetting the Dremel and drilling one set of holes and then offsetting it the other way and drilling the second set. (I wanted Pairs of holes for earrings).
Another problem was that the indexing head was a bit sloppy or loose. The Piece could rotate slightly. In my case, I just pushed it to one side or the other, every time.
If this sounds like something you are interested in, let me know and I will take a picture and post it.
>Are you drilling on a finished bowl or drilling from the outside but the inside is still solid? If its a finished bowl, how do you deal with "blowout" when the drill bit comes through to the inside?
>Chip - I made up a rig using bushings available from Lee Valley that would work for your task. In this shot I was making dimples to glue crystals on the top finial of an ornament. Details are written up and available at our Golden Horseshoe Guild website at the link below.
>Being the cheap person I am I made a 2 "things" out of plexaglass. One is devided into 10 degree segements and the other is 15 degree segements. When I want to devide a bowl in segements I just lay the "thing" on the rim and with a pencil mark the holes that are over the rim . ThenI use a center finder to mark across the rim. Then a square to draw the lines down the side on the bowl. Then All I have to do it drill the holes.
If this confuses you guys I will try to take a picture tomorrow and post it.
>Mine is similar to his but without the bushing. I used Oak. I made my jig square and drilled different sized holes high and low and on two sides. This gives me 4 different holes.
>...I am, I eyeball and start drilling the pieces on which my wife adds pine needle rims. Not too much problem with tearout if you don't push too hard and use a sharp bit. A strip of masking tape on the back side also reduces tearout when necessary.
