roughing an end grain bowl or vase
Steve Kubien
Steve Kubien
>Evening everybody,
I have a chunk of wood that I think will make a nice pair of bowls or a vase. I haven't turned end-grain before except for a bit of practise with the Oneway tool. Hey, I'll give it a spin!
Should I rough turn the blank with thick walls like I would for a cross grain bowl along the 10-15% of diameter ROT? Do I wait a few years for the blank to dry on its own? I don't want to ruin a nice splated maple blank (two of them actually) because I screwed up basic procedures.
Thanks for your help,
Steve Kubien
Re: roughing an end grain bowl or vase
>Steve, Its my opinion that the larger the piece of wood is the more likely it is to split.
So, I would do one of two things, either rough out the blank as you suggest and leave the wall thickness somewhat excessive or turn it as is to finish as quickly as you can.
Actually, I would most probably turn it now to finish. In one day or as quickly as I could and I would keep it in a plastic bag anytime I left the lathe for more than a very few minutes. I bag them when I go to lunch, and I don't take long lunches. The piece will warp and ripple as it dries after you finish it. I like that. It gives them a organic sort of "How did you do that?" feel. If you like the "perfect" round polished surfaces you need to rough it and let it dry for several months or longer and return it.
Steve Kubien
Steve Kubien
>Thanks Barry. So, it's the same rules as a 'regular' bowl. The blanks are well sealed right now so I will practise some more of lesser stock to get the hang of the end-grain routine. Then I've have at it in one go. I like working that way even if I do have trouble with sanding.
Cheers,
Steve Kubien
