A55 Smoothing Plane
Vaccum Pump NPT
Vaccum Pump NPT
Vaccum Pump NPT
Sean Troy
>Hey all, can you use plumbers tape to make the connection on the NPT ports on the Pump? thanks, sean
Re: Vaccum Pump NPT
Re: Vaccum Pump NPT
Bill Hale
>Sean
Plumbers tape is a very thin tefflon that fills and seals threads on fittings. It is not a tape.
Good turning and be safe
Bill in Show Low, AZ
Re: Vaccum Pump NPT
Re: Vaccum Pump NPT
Russ Babbitt Jr.
>I know it as teflon tape.....yes, use it..
Re: Vaccum Pump NPT
Re: Vaccum Pump NPT
Carol - now in NC Nebraska
>Three wraps, Sean. Used to teach vacuum technology for woodworkers. Our experience (building dozens of vacuum systems in class) was that three wraps worked best.
Glad to see you're going to Indy Fest. See you there. Tell me all about the move from Arizona, and why no Desert Turning next spring???
Re: Vaccum Pump NPT
Re: Vaccum Pump NPT
Sean Troy
>Thanks for the info. Looking foward to Indy Fest
Re: Vaccum Pump NPT
Re: Vaccum Pump NPT
Walter Ahlgrim
>I see no reason to risk it, the clearances are so small in a vacuum pump. Teflon is there to lubricate the threads so you can tighten them to the point that tapered threads seal. Get a tube of Teflon pipe dope it lubricates better. I stopped using the tape, after I disassembled a joint and saw how much ended up in the pipe.
Re: Vaccum Pump NPT
Re: Vacuum Pump NPT
>I assembled what passes for a system with Teflon tape and it seems to work fine, but I tend to agree with Walter. MY OCD side was worried some of the tape would get sucked into the vacuum pump. I was careful to wrap the tape on the threads and not let it hang over the end of the pipe the way I do when I am doing plumbing. (On plumbing I figure the stray loose strands would just flush out.) Do be careful to keep the inside of the system clean. For example if you ream any of the pipes, be sure to blow the metal slivers out before you assemble.
