Re: Hollow form rechuck
Bill Grumbine (Kutztown PA)
>Ryker, a tapered cone that Carole describes is a good way to finish most hollow forms. I can see where that might be a problem with this one. The compression needed to make it spin could very well crush it. I do not know the origination of the technique, but a man local to me gave us a good solution that will work for you, and is very similar to what Carole proposes. It is called the Kirtsen Cone, and I learned it from Kim Blatt.
Take the cone Carole describes, and run a shaft through it, with a pad on the bottom. The cone fits into the neck of your hollow form to center it, and the shaft with the pad contacts the inside bottom. That allows the driving force to be at the bottom of the piece between centers without stressing the rest of the form. You can now turn the tenon away without crushing the piece.
Good luck with it, and if this is not clear, let me know and I will try to clarify it for you.
Bill
