Drop of Ash HF 5246
Drop of Ash HF 5246
Drop of Ash HF 5246
Bruce Forrest
>Well, my General is up and running again, but don't get me started on the factory service.
On a much happier note, I've tried it out and produced this ash hollow form which measures about 10 inches tall. People lift it up, find it extremely light, can't see a hole to hollow through and seem a bit perplexed. I just tell them its a new hyrid--feather ash.
Re: Drop of Ash HF 5246
Wow, that is cool!
Ruth Niles
>I love the form and the wood is beautiful, too. Ok, so how do you hollow it?
Re: Wow, that is cool!
Bruce Forrest
>Thanks. As for the hollowing, it's through the bottom. Piece is mostly turned on the outside except for a bit near what will be the top end. This end has the tenon. Then the piece is hollowed, and parted off. The tenon end is made into a plug and all of a sudden there's no hole on the bottom, but it now has a tenon for mounting and finishing the top. Then reverse and vacuum chuck to finish the bottom off.
WayneLeach - NW Ont
>Bruce,
I like what you did with this Ash! Looks lovely and thats a neat idea for hollowing and concealing.
Wayne
Lovely piece
GaryG in MD
>I love it. Great extention of your earlier shapes. Thanks for the tips on the approach. Good stuff. ...Gary
Steven Antonucci
Can you post a picture of the "plug" hole?
steve antonucci
>I saw Ed Kelle's work at Five Barns, but it was much smaller and airbrushed, so I assume it would be easier to disguise the hole? I'm guessing that you align the grain to deal with wood movement, but I'd love to see your secret for hiding the "glue ring" I've always gotten when I try to save a piece that I've just cut through the bottom...
Like the piece a bunch, BTW. How thin do you hollow before plugging the bottom? I think it would be fun if it was like a 1/16" or something crazy- you'd have to put lead shot in it to keep it from blowing away :-)
Steven
Re: Can you post a picture of the "plug" hole?
Bruce Forrest
>If you look for it, you can still see that it is plugged. It just isn't all that obvious at first glance. With this ash, part of that is because it's camouflaged by the growth rings which are quite close together as you can see from the top. The plug itself has the required grain orientation etc because it is the same as what was removed, just a few inches further along the trunk. The plug is even more hidden, of course, in the dyed droplet shapes with the very small holes which I have posted previously.
