A55 Smoothing Plane
Using A Balloon For Crushed Stone Inlays In Voids
Steve Russell
>Hello,
Here is a quick and easy trick using a balloon as a back up device for deep void filling when inlaying crushed stones. The face of the balloon is waxed lightly before insertion into the project. After insertion, the balloon is inflated just enough to seat against the void area and thereafter acts as a removable backstop for filling a deep inlay. When the inlay work is completed, the balloon can be easily removed.
P.S. Apologies for the photograph... My scanner is on on its last leg.
Steve Russell
Wednesday Night Turning Chat Moderator
Re: Using A Balloon For Crushed Stone Inlays In Voids
David Breth
>That is very clever. Sipmle is frequently best.
Ron in Drums PA
>Reminds me how we would make masks with papier-m�ch�.
Kids loved that project
Rick Allen
>Trent Bosch does a "vessel within a vessel".
The clamp which is used is a balloon.
Re:But Trent says that.....
Jamie Donaldson
>... only a purple balloon will work correctly!!
Rick Allen
>"My friends say she's a dumb blonde but they don't know she dyes her hair."
Thomas Dolby - Aliens Ate My Buick - Airhead
The MountainMan
>My only question is how did you turn the knot??
Also for making pottery vessels
Bill Howatt
Mike Stafford
Where was this idea when I needed it?
Mike Stafford
>I was turning a piece of eucalyptus burl that had decided to come apart on me and I was trying to think of a way to consolidate the remaining material. I used layers of masking tape on the inside but the balloon would have been much better. Great idea!
Think your scanner bed could use cleaning!
Carole Valentine
>Wouldn't want the balloon to pop while I was filling the void! LOL Might be a good time for a face shield.
WayneLeach - NW Ont
>Some of the best ideas are so simple but never that obvious. Thanks for sharing it!
Wayne
Steve Russell
>Hello,
Turning the branchlet area was easy, although it had a large area that had totally rotted away. The piece was turned to near finished size and sanded. Once the area was filled, I began with 80-grit abrasive on a stiff backed sanding mandrel. This was held "off" the surface of the wood, but allowed to contact the stone inlay area. Once the rough excess was removed, I progressed through the grits to 320-grit. At this point, the area was flush with the surrounding wood and the final sanding was completed, taking the surface to 600-grit.
Since this was the only fill area on this piece and since it was so large, I had to counter-weight the opposite side of the piece, otherwise it would have vibrated excessively. I used the Kel McNaughton Balancer for this, which has two 5lb. weights that are independently moveable. This allows you to fine turn the weight for a smooth running work piece. Had I not used this balancer, the piece may well have torn itself apart from the centrifugal force as it was quite punky. Take care and all the best to you and yours!
Steve Russell
EWW, WVP, EWWFS
Steve Russell
>Hello,
Thanks everyone for your comments. I hope you can use this idea at some point in the future. Take care and best wishes to you and yours!
Steve Russell
EWW, WVP, EWWFS
