vacuum chucking question
chris rolke
>i hope someone can answer me on this
i have found an ad for a
"Like Brand New Schuco Inc Model 132 Air Compressor , It was used as a medical pump and a medical supply house was going out of business sale it work great on my air brush , Iam selling the pump cause I no longer use it and I loaned out my Air brush and never got it back ,"
i am trying to figure out if this would work for vacuum chucking
some of the specs i have found online are
"The Schuco� Model 130 high volume aspirator and suction system is simple, portable and reliable. Designed to suit the needs of the uncompromising professional in the hospital, institution or physician's office, this durable unit has an ultra-strong lightweight casing and controlled vacuum regulation from 0-22'' Hg. Voltage is 115/60."
so will it work?
Re: vacuum chucking question
Re: vacuum chucking question *LINK*
chris rolke
>here is a link to a pdf with more info
info
chris rolke
>according to the info i found it says
"this durable unit continues to meet the need for controlled vacuum regulation form 0" up to 22" Hg with a flow rate of 28lpm"
the gast pump shows
"0.5 CFM at 26" Hg max."
when you convert lpm to cfm it figures out to .98888 cfm
then this should work right?
How much does he want for it?
Ron in Drums PA
$50
chris rolke
Not a bad price, they're $360.00 new
Steve Russell
Go for it,
Ron in Drums PA
Pass it By
>Here's why.
While 22" of Hg is sufficient for most vacuum chucking, you need a flow rating of at least 2+ CFM to compensate for leaks in the system and porous wood. 1/2 CFM is totally insufficient. Would work well for veneering however. The "used" sealed compressors I get for FREE from the appliance repair shop pull 2.3 CFM and I use a pair of them in parallel. Remember, every vacuum check leaks a bit around the seal which is flexible and passes some air. This is also why you need a good filter in your suction line to protect the pump from wood and abrasive dust.
What you are looking at is a medical unit that must have a very gentle flow to avoid injuring a patient.
Hope this helps.
mm
Re: Check Sum
>Chris,
I think your math is a bit off. 1 CFM (12x12x12)" = 1,728 IPM. At 28 IPM you're moving about 1/60th of a CFM. See my post below.
mm
Re: Check Sum *LINK*
chris rolke
>if i am reading it correctly it was liters per minute
see link
linky
>28 LPM is about 1 CFM. It will work, but not really enough airflow. Not where I would start anyway.
chris rolke
>ok
thanks everyone
i am looking to save money doing this but still doing it the right way
Re: "l" vs "i"
>My mistake. 1 liter = 61 ci so you're right at about 1CFM. Still way too little flow for safe chucking on a lathe. Remember, the original vacuum chucking idea (Australia, I think) used shopvacs with low Hg. ratings but huge flow and waterlift ratings.
Furniture makers use this kind of unit in the full-sealed veneer press deals where the pump runs intermitantly on a vacuum reservoir to maintain a constant pull over a 18 hour "glue-set" period.
mm
Bill Hale / The Wood Spinner
>For $ 50.00 you can't get hurt. If nothing else just use it on smaller stuff. 1 CFM is not all that bad. Just be sure all of your parts, jigs etc are made of a non porus materials.
Good turning and be safe
Bill in Casa Grande,AZ
You can't get cheaper
>than FREE.
The pic is of my setup using a pair of dehumidifier compressors and a cooling fan I got for free from the local appliance shop. Once the freon is removed, these guys junk them. They're yours for the asking. Takes a bit of piping and wiring, but my whole rig that pulls 5 CFM and 26" of Hg cost me all of $10 to put together.
mm
View #2
Anchor Steam in the background here?
Michael Stadulis, in Gloucester County, NJ
Re: Sammy's Summer Ale |;-}
Re: View #2
Juergen
>How's the noise for this setup? Also, what's lubricating the unit with the coolant removed?
Re: Q&A
>Noise? They purr with about the same volume as a couple of cordless drills. Whole thing sits in a box with a furnace filter at one end and the fan at the other. Note here that the cooling fan is REQUIRED. This things have internal thermal overload breakers and are designed to operate in an air stream for cooling. Without the fan to keep them cool, they will heat and stop running after about 15 minutes, and you get to play Follow-The-Bouncing-Bowl.
Lub? These units are oil-filled. Not lub'd by the coolant. I did tie the "exhaust" (smaller compressed-gas) lines together into a condenser coil as they will throw a little oil mist. Drips into a cup and will gather about a 1/4 teaspoonful after 12 hours of operation. Once a year I'll put a teaspoon of Select (synthetic) compressor oil in the intake. They've been fine for 4 years, but replacements are free if they give up the ghost. The ones to get are out of 50-pint dehumidifiers. Frige and small A/C units are not sufficient.
Note #2. Since these are oil lub'd, you need to keep dust out of the air stream. Therefore a good in-line air filter is also a must, but that's true of all vacuum chucking setups.
