Web site to make your own wood handles?
Doug Thompson near Cleveland
>I've seen web sites that show how to make your own wood handle. For the life of me I can't find them, could someone be kind enough to post some sites.
Thanks Doug
Re: Web site to make your own wood handles?
tm
>i had seen one at www.turnwood.com but the link failed
sorry,
tm
tm
>the stebcenter video at www.robert-sorby.co.uk/ has how to turn an eccentric tool handle.
Richard Raffan videos also show handle turning.
tm
>Thank you, I need to make a simple how to guide and need to use the fewest steps possible.
anymore...
I think Alan Lacer's site has details.....
Michael Stadulis, in Gloucester County, NJ
>Doug I have several articles that I forward to people but it doesn't have any photos yet. I can probably put one together pretty quickly. The basic steps in making a tool handle are very simple. The complexity comes in with what material you use for the ferrule.
For simplicity, I drill a hole for the tool. Mount between centers with the tailcenter in the hole. Turn the tenon for the ferrule. Install the ferrule. Turn the handle and turn the ferrule if you want. That's it. You can turn it first and drill a hole for the tool but I've never been able to get the tool exactly centered. I don't think exact centering is necessary but sure does look better.
Alan Lacer's Site *LINK*
Brian Hahn in SW Wisconsin
>It's near the bottom of the list of articles.
Alan Lacer Woodturning
Getting hole centerd and more
Mike Brazeau
>Making tool handles is a great use of basic skills and everytime you pick up the tool you can enjoy your work. Start using a 2 or 2 1/2" blank about 15" or so long. I start between centers and leave a tennon on what will be the butt end, to mount in my Talon chuck. Mount with the ferrule end towards the tailstock, start reducing diameter and shaping and turn the ferrule area to diameter by trial fitting. I like to use the ferrules available from LV. They are inexpensive and make a truly professional looking handle. Get a feel for the handle by grasping it as you shape it. Complete the shaping, sanding and finishing of the rest of the handle except for parting off the butt end. I have used Mylands Quick Build as a finish, jelled urethane or danish oil with good results for all. Mount a jacobs chuck in the tailstock with the appropriate drill and drill the hole to the correct depth. Reverse chuck with the ferrule end in the chuck jaws and the dimple centered on the live center of the tailstock. Part off the butt end with a skew or parting tool and sand and finish. Dismount and mount the ferrule and tool shaft. I usually use some CA or 5 minute epoxy. Enjoy. Here are some examples from the past couple of years. L to R - Maple 1/4" point tool (short handle experiment), osage 1/4" drill rod scraper, honey locust point tool from shock absorber shaft, honey locust 1/4" round skew, osage supported ornament hollowing tool and osage Oneway detail spindle gouge. When processing bowl wood often half the log won't make much of a bowl, so cut it into 2 1/2" square spindle blanks. You soon have a ready supply of handle blanks.
Cool! Most people here are well "rounded"
>in there turning skills and can make almost anything. A handle should be simple but if you never did it before tough to discribe.
Note to self; take a spindle class!
Thanks again, I knew you'd come through with a answer.
Re: The classic is an old VHS tape.....
Jamie Donaldson
>... that David Ellsworth made showing how to make a handle from a tree branch, leaves some of the bark on, and makes a ferrule by wrapping with string and CA glue!
