Conover that's been hard at work
Jake Niedling
>Well I finally decided to battle the heat today and rough out a couple of 10" diameter cherry bowls. Don't hear much about the Conover lathe these days, so I thought I would show one that has been hard at work. Oh, by the way, this photo shows my complete wood turning studio in the garage. I am sure no one is jealous, but some times you just work with what you have and enjoy it and I do.
Re: Conover that's been hard at work
Carole Valentine
>I think that is going to be the type of space I am going have to put up with for a while after I move into my Mom's house. At least until I can build a shop. Don't know where I am going to put all my stuff! There is a two cat garage, but right now I have TWO 2-car garages chock full. Have never been one to leave the car outside, but I guess that's going to have to change for a while. :(
Lan Brady
>Jake,
How do you get the shavings to fall in that neat little pile?
Enquiring minds want to know?
Good post, Lan
>Jake I always liked the Conover lathe. That's a sweet machine. Hope to see you Wednesday.
E.T.
>Jake; Photo shows that a woodturner doesn't need a big shop to spend some "quality" time making wood round. Nice to see your Conover. Can you tell us how the motor is mounted? Maybe a photo? I use the old hinge mechanism but I bought a steel platform from the company before it closed and I wonder how well it works? ET
Doug Thompson near Cleveland
>Nothing wrong with a Conover lathe... matter of fact they do look better than a powermatic.
Ernie was nice enough to include the Thompson on his tool list. He uses the 7/16 detail gouge as a primary tool. Cool!
http://www.conoverworkshops.com/shaker-rocker-tool-list
Ray Binnicker
>Jake,
I've always admired the Conover. A friend of mine has one. My only question is: "what's the broom for" ?
Ray Binnicker
Da Broom ========
Jake Niedling
>Well I keep moving it, but da wife keeps putting it back. Something about keeping da wood chips from coming into the house from the garage ( I mean my studio). I needed 3 garbage bags and a shovel to clean up the mess.
Jake Niedling
>ET - The motor is mounted on a sliding base with slotted holes. The motor is slide back to tension the belt. A small block of wood which is shown in the picture is light colored was cut to hold this spacing. The bolts are then tighten to keep everything in place. This unit does have variable speed and I never seem to have a need move the belt to any of the other positions.
Jake Niedling
>ET - another view.
Jake Niedling
>When I retire, I see a workshop in my future. Working in the garage forces me to keep the tools limited to just turning related items. Also, it can be uncomfortable in the summer and dead of the winter. I turn when I can, but also doing it for a serious hobby. That way I have no commitments on me. Best of luck in your move and getting everything set-up for turning.
Jake Niedling
>Well the wood shavings have only two ways to go. Either back against the wall or against my big body. From there, they fall down under the lathe.
re: Thanks for the pics.
E.T.
>Jake; Thank you for the photos. These will help me a lot when I up grade my Conover to a VS motor. The hinge thing works OK for the motor that I use now but I am looking forward to having the VS.
Is that a 1&1/2 hp motor? ET
Re: Da Broom ========
Gary Evans Tallassee, TN
>Hi Jake,
You need to explain to your wife that the wood chips provide cushioning between your feet and that hard concrete floor. This saves money by helping to avoid trips to the podiatrist. The more chips, the more money you save.
(Let me know if this works. Hasn't worked so far at my house.)
Gary
David Cockey
>What motor and speed controller do you have? I acquired a set of Conover lathe parts last spring and need to build a base and add a motor.
Re: re: Thanks for the pics.
Jake Niedling
>I do not know the motor HP. I bought it about 7 years ago like this. It has a Jordan Speed controller on it. I was told that this was sold by John Jordan, professional woodturner from Tennessee years ago. He might be able to provide you with some information. It has forward and reverse. It has worked great with no problems.
Jake
