Have a question? Ask Woody!
Off center or multi center woodturning
>I've gone through most of my books in the last week doing research for my off center demo. If your interested in doing some of this the best books I've found so far are:
Multi-center woodturning by Ray Hopper. He gives a bunch of fun projects and some really good ideas on how to mount work to achieve off center affects. The examples are clear and the projects fun. Some are quite challenging to your turning skills.
Woodturning Methods by Mike Darlow. He has a 3 chapters on multi center, elliptical, and eccentric turning. As with all his books there are a lot of excellent diagrams and examples that help you design your own projects.
Off center turning requires some beefier tools and higher speeds than you might be used to. By beefier I don't necessarily mean bigger just designed to handle the stress of hanging over the tool rest a pretty good way. I like the Thompson spindle gouges and the P@N spindle gouges because they are thicker on the bottom and absorb more vibration.
When your turning off center work, particularly when your have a lot of air between the cuts, it is important to stay light on the bevel. Push the tool down on the tool rest when you feel vibration, not into the work. I don't know who coined the phrase gliding the bevel but that's what you want to do. Glide it don't ride it.
Re: Off center or multi center woodturning
Brian Hahn in SW Wisconsin
>I've been doing some multi off center axis pieces recently. I'm cutting air 80% of the time and the only thing I can ride (or glide) is the tool rest. I like a spindle roughing gouge because it takes a wide shallow bite and has enough mass to be stable, especially at the low speeds I've been using.
Re: Off center or multi center woodturning *LINK*
Darrell Feltmate
>Thanks John. I have found turning a wooden spoon to be a fun project with a bit of off center work. Recently I turned a few which still need the bowls carved out, but it will be a while since we have to move my daughter to her apartment in Ontario (from Nova Scotia) in the next week. I used mostly a 1" skew for the turning but for some of it a roughing gouge or a spindle gouge would be good.
Wooden Spoon
>Brian I always use the rough out gouge as long as I can but on some shapes the upper wings get too close to the work. That's where a good thick spindle gouge comes in.
>Darrel There was a pretty cool jig in the multi center book on turning the recess in the spoon. Of course you need enough swing for the handle to clear the ways.
Bob Moffett
Bob Moffett
>John,Which book are you referring to?
Both books have spoon turning jigs.
