How to use a scraper.
bhenr99
>Is there any info or videos on the internet that show how to use a scraper? I never used one. Thanks for any help.
Bob
bhenr99
Bob
Re: How to use a scraper.
>Bob Using a scraper is both easy and difficult depending on your technique. There are several techniques that make it easier. One is to sharpen on a grinder and leave the burr on the top. I have experimented with different angles on the bevel. I'm now using 45 degrees but I suggest about 75 degrees for people new to using a scraper.
When using a scraper start with it flat on the tool rest. Make sure the handle is higher than the scraping edge. This prevents most catches. You don't ride the bevel on the tool, only the upper surface with the burr touches the wood.
Use really light cuts. Start off by touching the wood as light as you can. When you get a feel for how it works you can apply more pressure. On a round nose scraper I grind the left side back about an inch. If you leave the left corner the way many of them come from the factory you can get a catch when that point touches the wood, so I round it off.
Jake Niedling
>I agree with what John has told you. A round nosed scraper is usually an easy tool to use. Make sure to keep your tool rest higher (above centerline) than you would when using a bowl gouge. This will require you to raise the back of the handle to get the top burr on or near the centerline. If you remember to keep the back of the tool handle higher than the cutting edge, then it should work well. I agree with John in grinding the left side back as well. Keep the tool down flat on the rest. Also regrind often to keep a sharp burr. This tool can cause some torn grain and is why many turners prefer not to use scrapers. I think you will fine that using the right technique, right woods and sharp tools you can be successful. But continue to learn how to use the bowl gouge and in the long run you will be much happier with your finished turning.
Re: I made a scraper for .....
Jamie Donaldson
>... emergancy use, when you just can't round that profile with a gouge. It is similar to the Sorby with the round back shaft- allows turning the cutting tip burr on a diagonal for a cleaner shear/scrape with much less tearout and tendancy to catck. The shaft is a 3/4" bar of cold rolled steel from Lowes, and the tip is a HSS shaper blade I found on the bargain table- 3 tips for $5!! Grind a flat on the bar and drill/tap threads for the shaper bit- makes the radius adjustable by moving the tip. And a fraction of the overpriced Sorby Multi-tip tool with the other useless tips! I think I have a photo on my desktop that I can post later if anyone would like to see it?
Paul Zerjay
>I did the exact same thing as Jamie, except I use old jointer blades as my tips. One more thing, if your not getting ribbons coming of the tip, you need to resharpen.
Carole Valentine
>Jamie, glad I read your response before I went into detail about making a shearing cut. I use that method all the time with my Sorby multi-tip and the teardrop scraper, thanks to Barb Gill. I had always been careful to keep the shaft flat on the toolrest like I did with bar scrapers until she showed me how to angle it to get a shear cut and nice fine little curls. Duh!
Wally Dickerman in Arizona
>All good advice...remember, except for shear scraping, on the outside of the piece, cut below center and on the inside a little above center. A light touch does it, and go with the grain.
Wally
Bill Hale / The Wood Spinner
>Some may not agree on this one. I sometimes roll the scraper edge to a high angle and do a very light presentation to the wood. My scraper is mounted in a 3 ft. piece of 3/4" gal. pipe. On deeper pieces the tool is basically round.
Good turning and be safe
Bill
Jamie... post the picture...
DWR
>... please...:)
Dave
Re: Will post it tomorrow...
Jamie Donaldson
>,... when I have the big computer on.
Re: Works for me, too, Bill.
Allen Neighbors
I'll go with Wally on this one...
GaryG in MD
>...you want the tool to move down into air, not wood, if something goes wrong. That means cutting above center on the inside, and below center on the outside. Trust me, I learned the hard way.
Now if you really want to stir up a hornets nest, Bob, ask about dropped-nose scrapers... ;-)
...Gary
Re: Is this - How NOT to use a scraper?..
russ Fairfield
>To answer the original question, I don't know of any instructional material on using the scraper other than an article I had published in the AAW Journal about 5 or 6 years ago. You might look for it if you have access to back issues in a club library or from another woodturner.
The concensus at the time was that real woodturners don't use scrapers. The article was written as a counter to this attitude among the new generations of woodturners.
The reality is that the scraper is a versatile tool that has many uses, one of which is shown in the photo. Yes, it is riding on the bevel.
dual use tool
TDaniel
>Bob, any tool you have can be used as a scraper. If the handle of the tool is held higher than the tip you are usually scraping. Many so called "scrapers" can also shear cut, that is with the handle lower and riding the bevel. Shear cuts will catch very easily. A term used by many is shear-scraping. To me this is a bad term. To scrape the handle is high, to shear the handle is low. How can anyone hold the handle low and high at the same time? I sometimes scrape at an angle and I sometimes shear at an angle but I never shear-scrape.
TD
>Sounds like you're shear scraping Bill. As I mentioned, shear scraping should be done above center and it should done with the handle down.
Wally
