Remington electric chainsaw saga update
Jim Miles - Charlotte N C
>I have posted over the past 6 - 8 months about my experience with Remington electric chainsaws. They keep dieing on me. They apparently overheat with little use, start sparking, smoking and die. It is obviously a manufacturing defect. I have been through 8 in the past 18 or so months, and I really don't use it much. At least Lowes has let me exchange the old for a new one at no cost. The benefit is I have never had to sharpen the chain - just trade it in on a new one. Ha Ha !
Well # 8 died last weekend on some bowl blanks. I took it in this week to get a new one - low and behold they finally have come out with a new version. It is supposed to be 4 HP has a new design mechanism to adjust chain tension and it looks a little more beefy. Tried it out and it seems to work quite well so far. Will let you all know how it does.
Re: Remington electric chainsaw saga update
Barry Turner
>Most companies spend countless dollars to put their products through the paces. Think of all the money you have saved Remington in that respect!
Is it worth the hassle??
Peter Teubel
>A saw a month is a good indication that they are less that reliable. How much have you spent on fuel (not to mention TIME) to get all these "free" saws? I learned my lesson after 3 of those POS saws. Get a Stihl and be done with it.
Re: Is it worth the hassle??
Robin Corell in Atascadero, CA
>But think of the time saved in not having to sharpen the chain, did you not read the mans post? I'm thinkin I maight have to ditch my stihl and get me one of those. will it handle a 42" bar?
Robin
robo hippy
>I have a Husky electric chainsaw, and found out that you have to let the saw cut at its own pace, rather than pushing it. If you apply much pressure when cutting, it will burn up, not like a gas saw which just bogs down. Now instead of the electric chainsaw, I use my Laguna 16HD. It cost a bit more, but works so much better and faster.
robo hippy
>I'm glad to read all these posts on the cheap saws. A cheap saw is really all I can justify because I don't think I would use it much. However I really don't want a piece of junk so I guess I'll just save the coin and at least try for a Husky or Makita. Who knows if I get a good saw I might use it a lot. I can't saw early on Saturday and Sunday because the neighbors sleep in. With a good electric I could do whatever I want.
Re: Remington electric chainsaw saga update *LINK*
Darrell Feltmate
>I have been using a Poulan electric for a few years now. Basically I find that if you keep the electrics sharp and the chain oil topped up they last well. The only thing is, do not force the cut. Let the saw do the work. Before anyone chimes in about getting a "real" saw, I have a very nice Stihl but do not want to run it inside the shop and for one or two shaping cuts, the electric is a lot less hassle. One problem many people run into with the electrics is a build up shavings around the drive sprocket when ripping. Sometimes they can even push the chain off the bar. Make sure to keep the bar angled to about 60* or 70* and to periodically clear the shavings.
http://aroundthewoods.com
Mike Schwing from Md.
>Yeah, 4 horsepower on house current. Sure. Thanks for the update, hope this saw is better than the previous lot.
