New High Speed Piercing Tool...
Wally Dickerman in Arizona
>Just finished my first piece using my new 400,000 RPM piercing and texturing tool. A small, open bowl with a design on one side. A bit crude but I'm happy with it. There is a definite learning curve here but I learned quite a bit on this one. I'd been practicing on a thin flat piece of wood. The curved surface on a small bowl is more difficult as I knew it would be.
71 years after my first lathe and I'm still having fun!!!
Wally
Re: New High Speed Piercing Tool...
Carole Valentine
>Pictures, Wally, pictures! Is that faster than a dentist's drill or about the same? What kind of bits do use with it?
Doug Thompson near Cleveland
>I tried one at the symposium and it cut wood like butter. Give us some details.
>Carole, it is a dental drill and it uses carbide dental burrs. I bought it from Binh Pho.
After the finish is done and I part it off the glue block I'll post a pic....a very small one.
Wally
ET
>Hmmmm...Dental handpiece. Are these the ones Frank Sudol was getting from a guy in Saskatchewan. I have not yet fired mine up. You say it is a lot of fun??? ET
>Wally I'm dying to get one. It was on my list of tools to get but I had to move it down a notch or two because of other demands. When I took the class with Binh Pho I realized that this tool has a lot more carving options than just piercing. It is great for texturing and adding very small details.
Jennifer@Indy.USA
>Wally, you never fail to make me smile.
I can't wait to see what you're up to!
Jen :)
Re: Good for you Wally! If you......
Jamie Donaldson
>.. don't have to grow up then you won't grow old! A new toy for the young at heart is a good investment that never hurts!
Darryl Hansen
>Keep the drill perpendicular to the surface to get a good clean edge on the piercing. I also found that a fan running slow speed blowing away from me helps to keep the smoke flowing elsewhere. You can get the bits from a couple of places. Much fun and the results are satisfying.
E.T.
>Can I use the compressed air as it comes out of the compressor tank or should it be filtered and dried?
My dentist says he has automatic oilers on his tool but these dental handpieces should be periodically manually oiled. How often do you oil yours?
The instructions with mine say to use Fordom air turbine oil, but i have never seen this oil, What do you use?
ET
>The tool is whisper quiet but the #@&* air compressor comes on frequently and is loud. I wear ear muffs along with a 2x magnifier. The tool blows a little air on the work which helps. I've tried some texturing and it works great. It will also work great for light carving. It comes with an air regulator. Needs no oiling. The best source for burrs is to have a dentist friend. Did I mention that I'm having fun.
The tool is a bit pricey (cost a lot more than my first lathe) but of course we justify that by selling some work.
Wally
Carole Valentine
>LOL Wally, you are like a kid at Christmas! I love it! I think that's what keeps you so young.
How much air pressure does that drill require?
>Specs say 2.0-2.5kgf/cm-2. Uses 38L/min. so that noisy thing over in the corner comes on quite frequently. Why doesn't someone invent one that's whisper quiet? One that I could afford that is.
Wally
Gil Jones on Lake Seminole GA
>Wally, my conversion program says that 2 to 2.5 kilogram/cm� equals 28.5 to 35.6 psi. What is the "f" for in your formula?
At 40 psi, my dental air turbine hand piece is anything but a whisper. It sounds like I am at the dentist getting drilled on.
Gil
George Van
>Good deal Wally, glad to see you are excited on the new tool. I am anxious to see your photo!
Darryl Hansen
>ET the NSK tool that I have does not require oiling. If yours does then you should use some sort of filter so that you do not get oil on the turning. I have a very quiet compressor used for air brushing. The regulator does have a filter on it. You need to have a compressor that will provide 3.5 CPM at about 4psi for the NSK handpiece. You can get oil at the power carver web site can't remember the url off hand
Darryl Hansen
>Wally I have an oiless compressor that is used for airbrushing. Puts out just the minimum needed to run the NSK but is so quiet you can talk on the phone when it is running. It ran about $200 I think. It probably does not run the drill at top speed but does work and both are quiet. Darryl
>That tool probably cost more than your first car. My first car was a 56 packard I bought for $90. Used more oil than gas. Heck I only paid $800 for my 63 ford falcon which was my second car.
>You're right John...my first car was 1931 Model A Ford...cost $125 in 1938. Wish I still had it!
Wally
