A55 Smoothing Plane
Earth Magnets?
Earth Magnets?
Earth Magnets?
Ruth Niles
>Where do you buy your earth magnets? I found 2 companies online, one sells the 1" circle, 12 pieces for $9.
Re: Earth Magnets?
Re: Earth Magnets? *LINK*
Jim Shaver - Oakville, Ontario
>Hi Ruth ,
I get mine from Lee Valley..
Take care,
Jim
Rare Earth Magnets @ Lee Valley
Re: Earth Magnets?
K&J
Dave Belser
>I use these guys all the time, creat selection, good price and prompt. Any of the "craft" companys will mark them up.
- Dave
Re: Earth Magnets?
Any particular size better or more useful?
Ruth Niles
Re: Earth Magnets?
Re: Any particular size better or more useful?
Mark Kauder, Phenix City, AL
>Ruth,
I am not sure what context your original question is - maybe a tread I missed. However, several years back, I bought a bunch from LV. I have 7-8 that are Hourglass shaped that I use on macines to hold chuck keeys, allen wrenches, tommy bars and the like close to where I need them - they never fall off, but are easily accessable. I also have a dozen or so 1/2" and 1" magnets that I have used for the same purpose (though they are harder to grab and pull off a surface) and have used them coutersunk and glued into various things to work as magnetic catches, with great results. Lastly, I took some of the flat ones, and turned decorative disks, glued the magnets to them, and made refridgerator magnets.
Be careful, it is easy to catch a piece of skin between two of them when they snap together. Also, the flat disks are brittle, and if let snap hard to a surface can break or shatter.
Mark
Re: Earth Magnets?
Lee Valley
Carole Valentine
>That's where I got mine. I use the 1" ones more than anything else to hold Allen Keys, chuck keys, wrenches etc. Also used those to make a featherboard for my table saw. Don't have any of the hourglass ones.
Re: Earth Magnets?
woodcraft
robert davis
Re: Earth Magnets?
>The quarter sized one will hold a jacobs chuck on the side of the lathe but I pinched a big blood blister on my fingers when I was stacking 2 magnets together. I got mine from Lee Valley.
Re: Earth Magnets?
Steven Antonucci
As others have warned...
steve antonucci
>BE CAREFUL WITH THE BIGGER ONES!
I have a bunch of the 1/2" by 1/8", and they will "stick to each other through my hand. The 1" ones I've seen have been advertised as "pulling objects off your bench" strong.
I get mine on Ebay, BTW.
Steven
Re: Earth Magnets?
Caution
Barbara Gill, Remlik VA
>Do not get them near any computer chips!!!! If you already knew this, pretend I didn't say it. :-)
Re: Earth Magnets?
Steve Kubien
I use the 1" ones and...
Steve Kubien
>...the recessed cups (sort of focus the magnetic energy) in a piece of 1x3 scrap. 2 foot length with 5 mags on one end. I use to pick up metal thingies (Sunday technical term) like screws for jaws, jaws themselves, Allen keys etc. Works pretty well in a pile of shavings.
Steve Kubien
Re: Earth Magnets?
Re: Caution
>Don't get them near your monitor either. My boss was playing with one of my magnets, distorting the image on the screen. I don't know exactly what he did after I left but it destroyed the monitor. Fortunately he's the computer guru know it all so we just left and let him figure it out.
Re: Earth Magnets?
Refrigerator magnet size
Dave Staeheli
>I make refrigerator magnets with the 1" magnets quickly and easily with my spigot jaws. When I get a small cut off of really nice wood that I hate to throw away, I mount it up in a chuck, drill out a 1" by 1/8"+ recess with forestner bit in a tailstock drill chuck. Than, as my spigot jaws handle a minimum of 1", I reverse the piece onto the spigot jaws and hold from the inside. Finish and glue in the magnet. The recess should be a hair deeper than the magnet. Do not allow the magnet to "stand proud", as it can scratch the refrigerator and "SWMBO" will become upset.
It allows me to make very shallow refrigerator magnets. With nice grained wood, it looks like jewels.
Re: Earth Magnets?
Re: Caution
JKJ in East TN
A strong magnet and a color CRT (or tube-type TV) is fun to play with - the image is distorted with a swirling kaleidoscope of colors as you move the magnet. When the magnet is removed, a residual magnetic field can remain leaving a color cast or cause the image to remain distorted in severe cases. This can be fixed by demagnetizing the screen, either with a standard degaussing coil or even a tape demagnetizer.
However, there is another way that is cheap and usually effective: hold the magnet in your hand and swing it quickly back and forth, starting fairly close to the screen and moving slowly away (swinging all the while). This almost always works. This can also fix the purple cast in the lower corners you may have seen in a CRT monitor when someone placed a small audio speaker too close to the monitor.
