Powermatic live center: removing pin
Aage Rendalen
Aage Rendalen
>I'm working on a Tom Crabb wannabe off-center two spout pot and need to drill through my tail stock. How do I remove the live center pin on my PM 3520B?
Re: Powermatic live center: removing pin
>It is a very small morse taper. Simply knock it out with the thin rod that you got with the tailcenter. It is usually used to go through the hole to lock the tailcenter from turning so you can install the threaded accessories. I just tried and knocks out the center pin quite nicely.
One of the reasons I like my Nova live center is the center hole is larger. I can bore a 3/8" hole through the nova. I believe it's only about 1/4 or possibley 5/16 for the Powermatic/Oneway live centers.
